Have 2 year old Frigidaire FAH105N1T Air Conditioner. Fan stopped working on fan or cool. Serviced twice and they said fan needed to be oiled. Worked 3 weeks then they said it needed fan motor. Bought new unit. Can I fix old unit and how ? Any thoughts ? THANKS Fr
  • 128 Answers
It possible to replace the defective as follow:
1- take out the unit
2- remove the top cover
3- try to take out the wires from there connections and note each color to witch connection
4- loose bolt of indoor blower to the shaft
5- open the bolt of the condenser fan to the other end of motor shaft and take out the fan
6- open the fixation nuts or bolts of the motor then slide it outside.
7 replace as take care about witch side of shaft is for blower or fan.
Posted on Sep 08, 2009
Motor on a/c is turning slowly. this is a old unit. hasn't ran for 7 years. there are 2 removable ports on top of motor. does motor need oil or something?
Hi The air conditioner does not have any places. to put oil in, if the motor is running slow or slow to start then I would suggest you look at replacing it. Ross
Sep 14, 2013 | Shopnbc Frigidaire FRA25ESU2 25,000 BTU...
Air conditioner not working
have you tried turning off and on power from the plug ?
Aug 17, 2009 | Haier HWR08XC7 Air Conditioner
When we turn the AC on, after a couple of minutes we hear a hum which lasts about a 1.5 minutes then shuts off. No fan air movement or cooling detected. The unit is 5 years old. We RARELY use it and when...
Go up on roof and using a stick or similar, poke it through the air holes in side & try to turn the fan blade at rear of the air conditioner. Make sure it's off at the time. Try to get 2 or 3 complete revolutions of the fan blades, then try turning it on fan only first,and let it run on fan for a few minutes, then switch to cool. If worse comes to worse and you can't get blades to turn, remove cover on roof (watch for wasps & bees) and spin fan blades a few times by hand, step back & have someone try fan only. If that works, then try cool. Sometimes they get a dead spot from sitting, and that will get it going again, 90% of the time. Let me know how it goes.
Jul 27, 2009 | Dometic Rooftop RV Air Conditioner
Fan works but not blowing cold air
Is the compressor running? If it is then you are probably low on refrigerant and needs to be leak checked and recharged.
Jul 16, 2009 | Frigidaire FAC125P1A Window Air...
Fan motor has loud screech.
Check for oil ports on motor. Usually red or yelloe plug in caps. No more than 20 drops of oil. I usually use sewing machine oil.
Apr 26, 2009 | Heating & Cooling
AC WON'T COOL
Sounds like you have a freon leak or your compressor has stopped working. You will probably need a service tech. If it is out of freon, don't let them just add more freon, make them find and repair the leak first. Good Luck.
Mar 27, 2008 | Intertherm P3RA-048K Air Conditioner
Fridge Stopped cooling
If the fan isn't running the "cold" won't make it to the refer section and the freezer won't get proper circulation of air. The "evaporator fan" must run when the compressor is running.
Jan 26, 2007 | Frigidaire PLHS269ZC Side by Side...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
