Question about Nokia e65 Cellular Phone
I have Nokia E65.Whenever I set it on charging it does not charge, rather the movement of charging cell continuosly shown.But after a lot of time the result is not-chartged even by a single cell.What is the problem? please tell me...
  • 265 Answers
Two problems can be there
  1. U r battery is faulty.. it needs to be replaced.. to check tht put it in sum other phone and charge it or chare it using battery charger in whch battery is directly fitted on the charger..
  2. other problem could be with the charging circuitry of the phone.If ur battery charges from other sources like mentioned above thn ur phones circuitry is damaged
  3. also there is a possibility of faultycharger.. so try charging with sm other charger
Posted on Sep 06, 2009
Help needed!!! Fresh new batery only 12h.Nokia E65 is charging normaly but battery works only 12h.Charger is O.K. It is charging other telephone good. H E L P !!!
Posted on Jun 11, 2010
I need to change charger pin
I would rather recommend you to get a new phone. cause i am not sure if there is anyone out there who would fix the charge pin. even if you find someone who can fix it that is going to cost you a lot.
Aug 27, 2013 | Nokia e65 Cellular Phone
Nokia e63 and e65
How to unlock Nokia E65 by code ?
Unlocking Nokia E65 by code is very simply . It is also safest and non-invasive method of unlocking your phone. Code to unlock Nokia E65 will be receive after entering IMEI number. You can get Your Nokia E65 IMEI number by typing *#06# or after removing the battery. IMEI is also written on the information label as shown in this picture.
To unlock your Nokia phone is needed to provide the IMEI number and select the correct network that phone is currently working.
Selecting the correct network and the country is very important. Choosing wrong network You risk receiving wrong unlock code.
If we have blocked counter we need to enter code or reset counter using USB cable by program below
How to enter Unlock code RESET COUNTER to nokia using USB cable
Code #pw+123456789012345+1# type in the following way:
1. Turn on the phone without sim card
2. Select character # on the keypad
3. Characters p, w, + get by choosing few times STAR *
4. Press # button to approve code
5. Message "SIM restriction OFF" appears, Your phone is now unlocked
WARNING!!!
You have only 3 attempts to enter the code. The last failed attempt will block the counter.
Jun 10, 2012 | NEC Cell Phones
FOR HOW LONG CAN THE BATTRY LAST BEFORE YOU CHANGE IT
How Long Does the Nokia E65 battery REALLY last?
Ever wonder how long the phone battery actually lasts? For the first use of my Nokia E65, I charged the phone for 24 hours after receiving it (still not sure if this is necessary), then took it off the charger Saturday afternoon. The battery low warning first sounded 54 hours later. This was after
•Calls: Around 15 calls made and about 3 calls received, with almost 40 minutes call duration in total.
•Data: 726kb data sent and 3.96mb downloaded
•WIFI: About 20 minutes of WIFI use
•Applications: Use of Skype and Gmail application as well as a bit of Nokia Maps and Google Maps
The battery eventually gave up after 2 more hourse of standby. The Nokia website says the following about the Nokia E65 battery:
•BP-4L 1500 mAh Li-Po standard battery
•Talk time (maximum): GSM up to 11 hours; WCDMA up to 4h 40 min
•Standby time (maximum): GSM up to 18 days; WCDMA up to 20 days;WLAN idle up to 170 hours
If you are wanting to make comparisons with the Nokia E71 battery life, this is what the Nokia website claims for the Nokia E71. The Nokia E65 and E71 both use the same battery - BP-4L 1500 mAh Li-Po battery but E71 is slightly more demanding on the battery life.
•Talk time:- GSM up to 10 h 30 min- WCDMA up to 4 h 30 min
•Standby time:- GSM up to 17 days- WCDMA up to 20 days- WLAN idle up to 166 hours
If you are willing to help, maybe you can do the same experiment for your Nokia E65. Use the call logs and the data counter under "Connectivity" and measure how long your Nokia E63 battery lasts with "normal" usage. Report your findings in the comments below and someone just as curious as you googling battery life E65 will also benefit from your efforts.
Your mobile habits may not be as demanding as me but I hope this helped you in your battery life calculations for the Nokia E65.
To charge a battery from empty to full, it took 2 hours and 40 minutes
....... If you are willing to help, maybe you can do the same experiment ... It lasts me about 40 hours before I get a battery low warning .... I got my Nokia E65
Jan 05, 2011 | Nokia e65 Cellular Phone
E65 not garging
hi,
it could be that the charging port is faulty and also ensure that the charger is working fine..
cheers.
May 18, 2010 | Nokia e65 Cellular Phone
Nokia E65 microphone doesn't work
hi thanks for using fixya!!
Did you accidentally dropped the Nokia E65? Well, on this error, you shoudl bring your unit to a service center to further check the hardware error such as the microphone. However, be sure that whenever you make calls you have the network signal high so that you can have quality voice calls.
If you need further assistance, let me know
May 26, 2009 | Nokia e65 Cellular Phone
Nokia e65 is rebooting
most probably ur phone is infected with commwarrior virus ..... remove memory card and scan with norton antivirus ... meanwhile take back up of phone memory and format it using *#7370# ....default code is 12345..... After cleaning the card then insert it and check
Oct 17, 2008 | Nokia e65 Cellular Phone
I hav a phone problem and a samsung 1gb mp3 player
both of your device have some hardware problem send it to service center for details checking.
Jun 20, 2008 | Nokia 6600
Nokia E65 dead during Nokia Software Upgrade
I was just upgrading the Nokia software on my E65, connected with USB, charged and connected to charger for backup... and the phone just went dead. I've tried everything to get it going again including taking the batery out and outting it back in aain, holding the on/off button down for a minute - and nothing is happening. The screen is dead. Is Nokia's new upgrade causing this? I see two other posts to this site with the same problem in the past 24 hours. The upgrade was posted on Nokia.com 24 hours ago. my mail is singh1316@yahoo.co.in
Apr 10, 2008 | Nokia e65 Cellular Phone
Nokia e65 Cellular Phone Logo
350 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
