Question about Hoover Dryers
My TC 650 is not getting warm anymore. It works but nothing dries as there is no heat! Please help!
  • 6,784 Answers
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
Posted on Sep 06, 2009
My Quickstat has stopped working completely. not a gfi reset issue, but zero display. there is still power to unit. Im guessing that I need to replace unit.
Raychem QuickStat-TC Installation & Operation Manual
www.manualslib.com > Brands > Raychem Manuals > Thermostat
View and Download Raychem QuickStat-TC installation & operation manual online.QuickStat-TC Thermostat. QuickStat-TC Thermostat pdf manual download.
Raychem - QUICKSTAT-TC, Programmable, Thermostats ...
www.platt.com > ... > Floor Warming > Thermostats > Programmable
$144.29 - ‎In stock
Raychem QUICKSTAT-TC Programmable Thermostat Programmable Thermostat, 120/240V, 16A, GFCI, 4 Programmable Events per Day.Missing: tyco ‎working
Raychem Quickstat Floor Heating Thermostat Installation ...
Dec 26, 2015 | Raychem by Tyco QuickStat-TC Thermostat
I have a whirlpool gold quiet partner III Black dishwasher. All of a sudden it stopped working. I push the accusense button and start the cycle for washing, it looks like everything is working normally, I...
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry . Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 30, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
My LER463rJQ1 dryer is only about 4-5 yrs old and it doesn't seem to be heating as well anymore. I don't know where to start...thermostat? heating element? or what.. What do you suggest.
I assume you mean the clothes are not drying as well or as quickly as they use to.? If so I would start with the Vent system ,85% of extended dry times are vent issues. Start by running the unit and going outside to the dryer vent and check for a good flow of warm air,if very little air is coming out of the vent you need to clean or have the entire exhaust system cleaned out.. With out good airflow you will just end up with warm moist clothing the airflow helps remove the moisture.. If not a airflow problem it may have a thermostat issue not letting it get hot enough or not staying hot long enough,,Hope this helps GOOD LUCK
Aug 27, 2010 | Whirlpool LER4634J Electric Dryer
My 2 year old sister threw my kyocera X-tc phone in the pool 3 days ago. The first thing I did was dry it off and take the battery out, I dried the battery and the phone again, and put the battery in. I...
Hello, There is still water inside the phone that's why some part are still working and some not working yet.
What to do is this,
Unscrew the phone,
Get a Methylated spirit and a brush,
Bring out the board of the phone and use the methylated spirit to brush off remaining water on phone.
Keep under heat to dry off,
After board is dried, fix it back and screw back phone.
Am sure after doing this phone will work well.
But if phone still doesn't work ,that means water has damage some component inside the phone.
You will need to consult a phone technician for assistance.
Take care.
Jul 03, 2010 | Kyocera X-tc Cell Phone
Whirlpool AWZ-7813 won't dry - no heat
it will either be you element or the thermostats that have failed.
Mar 20, 2010 | Whirlpool Dryers
Hi there ...I have the Kodak V803 Digital Camera..a week ago i left the camera in a -10 cold temperature in the glove box in my car..the problem is, when i try to take a shot, after the flash the screen...
1. Try to fully recharge the batteries, and then, use them in camera.
2. Keep your camera in warm environment (not too much close to hot surface) for 2-3 hours.
3. Now, check your camera performance.
please rate me if it helps..tc! :)
Jan 08, 2010 | Kodak V803 Digital Camera
No heat
Sounds like one of the fancy heaters. They have circuit boards that can go bad. don-ohio
Apr 13, 2017 | 1985 Ford Crown Victoria
Dryer gets hot when not running
Getting hot when not started is a great concern.
I have a few ideas why, but this is a fire hazard and I would suggest unplugging and either getting help or replacing.
That said, there here are a few suggestions.
1) if the element is shorted to ground, it will get power to one side of the element and heat though ground. This, again, is serious.
2) if it heats forever and doesn't get warm enough to dry, this is another indication of an element that is not working up to power. Not getting 230 across the entire element and not getting hot enough to dry.
3) Many times when a dryer runs too long, the air flow if blocked by the vent being plugged or some plug withing the dryer itself.
Again, I am very concerned about this problem and suggest you not use it until it is repaired. If you want to check the element, it is fairly easy, but unit will need disassembled.
Mr Boo
Nov 30, 2008 | GE Dryers
Water problem
Remove battery immediately You should take it to a repair shop to have it dried prfessionally, in the meanwhile open it, remove battery and any remomovable part, and leave it in a dry warm pace. if it is soaked dry it using an hairdrier from distance so that you do not risk causing heat damage to your palm.
Apr 27, 2008 | Palm Treo 650 Handheld
Tumble dryer not drying
Either dryer element has failed, thermostat for drying or the drying condenser fan not working.
There are two heating elements and the top one is for drying.
Apr 07, 2008 | Hotpoint Ultima WF860 Front Load Washer
Dryers Logo
109 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
