Question about Maytag Refrigerators
The hinge on the big door of my frig is rusted. how to remove the door is my question? model #MTB2156
  • Maytag Master
  • 1,606 Answers
Remove the bottom hinge first , then drop the door down and off .
Posted on Sep 06, 2009
Why is my frigidaire washing machine model # ltf2140fs2 door is hard to shut and the hinges are rusted
Good Afternoon Friend,
I understand that the door on your Frigidaire washer, model# LTF2140FS2, is hard to shut and the hinges are rusted. There could be a possibility that there is a leak that is rusting the hinges. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why the door won't shut and why the hinges are rusted. Hope this is helpful.
-Best Regards-
WP
Jun 10, 2014 | Frigidaire Washing Machines
I have whirlpool A CLASS fridge how do i reverse the door
  • I cannot confirm weather your fridge had reversible doors as you listed no model but the standard for fridges that can reverse the door swing are changed by doing this -
  1. You will see little plastic covers on the opposite side where the hinges and handles are currently located now.
  2. There are some little clips that hinge the screws on the top and bottom of each handle.
  3. Remove these little covers with a small flathead screwdriver.
  4. Now remove the screws holding the freezer and refrigerator handles on.
  5. Now pop the screw hole covers on the side of the frig/freezer you will using.
  6. Now place and fasten with screws the handles on the other side of the frig/freezer door.
  7. Now remove the top freezer hinge first by removing the 3 screws on top.
  8. Now pull up on the hinge (save the spacer).
  9. Now pull up on the freezer door.
  10. Now remove the screws on the middle hinge.
  11. Now pull up and remove the middle hinge while holding the frig door steady (save the spacer).
  12. Now pull up on the frig door and set to the side.
  13. Now remove the screws on the bottom hinge (save the spacer).
  14. Now put the screw hole covers you removed from the other side in the screw hole exposed from the screws you just removed.
  • The switch
  1. Start with the bottom hinge and place it on the opposite side (don't forget the spacer).
  2. Place the frig door on the bottom hinge and the place the middle hinge in the hole at the top of the frig door.
  3. Fasten the middle hinge.
  4. Place freezer door on the middle hinge.
  5. Put the freezer door in it's natural position to make putting the top hinge on possible.
  6. Screw the top hinge in.
  7. Job complete.
Regards, Tony
Apr 30, 2011 | Whirlpool Refrigerators
Oven door won't quite close tightly. I can push it about another 1/4 inch to close it completely.
You need to replace the hinges in the door. Go online to a spares website and enter make and model and order new hinges. You can replace them by unhooking the door, just takes a little effort, you might need to flick back latch on hinge and lift out. Remove inner door panel, usually 4 screws and remove. then change hinges. The 2 big pieces are the hinges.
  • images?q=tbn:and9gcsg1plmaxnucdapg-xpimmjauz_p4kgblmyf6iotcmgyh-hv4v3
Mar 09, 2011 | Ovens
THe door hinge on my GE front load clothes washing machine model # wssh300G1WW has rusted and bent and the screws are rusted. I would like to replace the hinges and screws but I don't think the...
I have the same washer & its 3 years old today. Rusted hinges & door & screws too.
Door is really hard to shut so I called GE to complain & they are overnighting me a new door, hinges, & screws. You should call!!
Oct 11, 2010 | General Electric WSSH300G Front Load...
Censor isn't working; temperature rising in frig (freezer ok)
Hi, do you think you could provide a model number. Some of those Samsung fridges have bad control boards at the back which could cause that problem OR the other possible fault could be the cabinet light sensor by the door hinge.( I'm going to assume it is this type based on the symptom you've described)Sooo...If you remove the hinge cover at the top you may find the receiving part of the sensor is misaligned or out of place completely which will prevent the semsor from detecting the door is closed, hence the interior light remains on and the temp rises and all sort's of unwanted side affect's. That is where I would start looking, but I don't even know if your unit has a push button door switch or the sensor style without a model number. However, based on several service calls for this exact problem in the past I'd say the chances are good it's the door close sensor if that applies to your model fridge. Hope that help's, let me know. Thanks for visiting fixya today. Good luck macmarkus :)
Dec 25, 2009 | Samsung Refrigerators
How do we adjust the door height on our GE Profile Side by Side frig, Model TPX24BPZC...it has slipped down and the trim kit keeps rubbing on the lower edge where the door hinges....????
Hello, Take the cover off the top hinge and then remove the top hinge and the door, the problem may be a worn hinge cam, if it is replace it. If the hinge is loose tighten the bolts. Once the door is off you will see how the lower hinge can be adjusted. Hope this helps! Mike
Dec 02, 2009 | GE Refrigerators
Door on fridge side has droped 10mm the plastic washer has worn away i think .Can i get a spare please its situated at the bottom of door
Take the model number ( you didn't list it here ) to a parts house and tell them you need the door closer for the frig door . To install , remove the 3 screws holding the top door hinge located under tho top hinge cover , and lift door off bottom hinge . Remove all food items from door first . The closer should come with a lower hinge and the piece which attaches to the door . If not , tell them you need the door piece also. Or the kit may come without the hinge , but , with both the hinge piece and the door piece in the package .
Aug 09, 2009 | Refrigerators
Refridge door does not close evenly on my side by
Top hinges can swing right to left slightly when all 3 screws are loosened under removable cover. Use a 5/16 nut driver. Hinge cover may be phillips, 1/4" or 5/16".However, fridge case must be level left and right first. Level fridge with adjusters behind toe kick cover. Once level, you can adjust gap between doors with top hinge movement. Keep in mind that this is a man-made product and you may not get the doors exactly straight due to lose manufacturing tolerances.
Jul 24, 2009 | Refrigerators
Remove jeep door
You just need to use a small drift pin punch to push the door pins out. Use a small drift pin punch and a small hammer to drive the pin up and out from the bottom. It is just stuck in the hole.
Mar 17, 2009 | 2003 Jeep Wrangler
Light not going out in viking frig when door is closed
you have a micro switch at the top of door by the door hinge.must remove top vent cover to access. i've found that if the screws (2 or 3 phillips ) get loose the door is not aligned to open and close the light switch . or maybe the switch itself has failed
Nov 26, 2008 | Viking 24 in. Professional Series VUD141...
Refrigerators Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
