Cd drive wont read any cds.
SOURCE: cd rw/dvd combo drive GCC-4242N WRITING PROBLEM
what brand , model number, and operating system you are using,,,
SOURCE: Acer Aspire 3000 DVD/CD-RW drive
If its the DVD/RW CD/RW unit it will possibly have...
NTI CD/DVD Burner which is a part of the Arcade System .
Easy to use and stable as anything I have seen before,3
Fast n Friendly,Remembering the max ram is 2GB and
with all barrells loaded performs like a beautiful piece of art.
Also Nero is an old favourite too.
Producing your own dvds from scratch is a satifying excercise and amazing when you can see the look in everyones eyes,,,,
Yes - Impact is everything.
I found your answer,
Grab you machine and look at the symbols on the disk draw.
The device you have is a CD/RW-DVD Rom.
What this means it is a CD Writer and a DVD Reader.
This device will never burn DVDs.sorry
To write DVDs you will need to buy DVD/RW device.
I hope this helps ,please rate me thanks
SOURCE: phillips dvd drive/cd burner does not burn cds
Might be the regestry, errors can accure throught the reg, nothing you did it just happens. Try this and see, "Start" "Run" type in "regedit" then ok in the left field click on the "+" next to Hkey_Local_Machine" + next to "System" + next to :CrurrentControlSet" + next to " Control" + next to "Class" then click on " {4D36E965-E325-11CE-BFC1-08002BE10317} " in the right fild click on "Upper Filters" then "delete" now "Lower Filters" then "Delete" restart pc. Hope this is helpfull.
SOURCE: Dell Optiplex 755 machines - TSST corp L632 drive-won't read CDs.
make sure that you are closing the CD and also make sure that the cat isnt licking the dogs balls while your doing it.
