You will not want to remove the back, if you do it will be very difficult to put back together. The way to get inside one of these is to remove the case. Vary simple and easy; Each end of your console has a cap that you will need to remove by pulling it forward from the top. It should un-clip. They are sometimes tricky and you should be prepared to replace the first one in case you break it. Once you have removed the first one you'll know how to remove the next. Now that you have removed the end caps, there is a screw under each. the screws hold the console on the top. After removing both screws, pull the console forward and then flip up. It should stay attached to the back. Now unplug the wires plugged into the top, you will see them a little to the right on the top, they were under the console. Now look toward the corners, you will see a square hole that has a metal clip. Use a flat screw drive and un-clip one on each corner. Your ready to take the cabinet off. Open lid, put a hand on each side of the whole you load the clothes in and pick up while you tilt towards you. The case comes right off. If you have the dispensers around the inside for soap and all. You will need to take these hoses off before you lift it off. You can now get to any part on the machine.
Note: If your machine is older than 3 or 4 years. You might want to replace your coupler while your inside it. It's also very easy. Notice the floor beneath the center of you machine. If you see a black powder, you will want to replace it. If not you will be before long anyway. These are great machines and the coupler is the most common thing to go bad within ten years. Good luck and i hope I didn't get to complicated, Remember I work on these every day and forget to mention things because I see them all the time. If you need more help just respond back.
Please rate solution.
