Question about Maytag Atlantis MAV6000 Top Load Washer
Water drips (tiny drop) slowly from top of washing machine when the machine is off (not from where the water comes from when it is on...but from that same direction). What could be the problem? (Maytag Atlantic Over size plus (loaded from top)). Thanks.
    President:
  • 1,776 Answers
Check the water inlet valve. Remove the water supply hoses and check the small screens inside the inlet valve. Make sure they are clear of rust or debris. Next, check the solenoids. They can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad solenoid. I will attach a photo for reference. Sure hope this helps and best wishes.
Posted on Sep 06, 2009
8.5L LG turbo drum washing machine. The cold water is coming out of the tap but dripping slowly through he machine? What do you suggest to do? But the hot water is working with no problems at all?
ck to see if valve that feeds cold water is open at least as far as hot water is ? also try closing water valves and removing hoses from machine , look into end (both) there are small screens inside there are they part blocked off by something ?
Jan 29, 2016 | LG Washing Machines
I have a 6.5L LG turbo drum washing machine. The cold water is coming out of the tap but dripping slowly through he machine? What do you suggest to do? The call out fee is $100 and $20 per 10mis ...
The water solenoid valve may have gone bad and is allowing water to enter. Turn off the cold water shut off valve at the wall to immediately stop any water from flowing. What is your machines model number?
Jan 15, 2015 | LG Washing Machines
Why does the rinse cold water drip in so slowly?
check filter (screen) in water valve intake and hoses to do so you need to take the water hoses off
Oct 07, 2014 | Whirlpool Washing Machines
My Seaco Royal Machine has got double problems. The first one is; water dripping from the bottom to the floor. The second is; coffee coming out slowly (drops ). The second is; the sounds that accompany the...
The leak may be due to a clogged weep passage that resides behind the brew group and empties into the drip tray in the front. Take a long piece of wire or a good paperclip and straighten it out. Take some hot soapy water and a small syringe and wash that area out with the drip tray installed. As for the coffee coming out too slowly, you may want to adjust the grinder to a more coarse grind by one or two clicks. After each single adjustment to the grinder, it will take two brew cycles to catch up to the adjustment. Don't make too many adjustments without running at least two cycles in between each adjustment. If that does not solve the problem, you may need to take it to the repair center nearest you to have them check out the pump.
Feb 03, 2014 | Saeco Royal Professional Espresso Machine
My ge top load washer will not allow cold water through it just drips out slowly. water comes out the water line but for some reason the machine wont let it through
Could be a clogged screen on the back of the inlet valve. If you have hard water and no water softener, especially likely. Turn off the water at the water, remove the cold water hose from the back of the machine and see if there is an accumulation of white crumbly material just inside the body of the valve. If so, carefully remove it, then use a screwdriver to remove the protective screeen inside the valve. It is a press fit and will come out with a little effort. Do not puncture it. Clean and reinstall, hook up the hose and turn on the water. Check for leaks and you should be back in business.
Mar 03, 2010 | Washing Machines
Water not coming with force in Fisher & Paykel SmartDrive Top-loa
Try taking the cold hose of at the tap and check to see if has a little mesh filter in there. This could be blocked up with gunk.
Jan 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Top load model 110.24422300 water drips out slowly into machine
HI. the inlet water valve assembly is damaged. replacing this valve assembly will fix this issue. It is located inside the unit, on the backside.
Jul 15, 2009 | Washing Machines
Leak
Your inlet water valve where the fill hoses attach is stuck open.
Mar 18, 2009 | Washing Machines
Water Dripping
you need a new fill valve, even if you ulplug the washer does it still drip? If yes then you do need a new fill valve. Just turn water off at the wall so your machine don't overfill.
Oct 28, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool washing machine, extra large capacity Plus. Water drips from the top back of the washing tub into the spun-dry clothes after doing a load. Dripping water source is higher and slightly to the...
it sounds is if you have a possible crack in the water supply area. if the hoses are good, tight and dry, inspect the housing base they screw into.
Aug 16, 2008 | Washing Machines
Maytag Atlantis MAV6000 Top Load Washer Logo
121 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
