Question about Whirlpool Dryers
When the dryer is hot and you open the door it smells like rubber burning
  • 612 Answers
Your dryer is getting to hot due to the cycling thermostat being bad. Also check you vent for clogs. If you don't replace the cycling thermostat your thermal fuse will end up going bad. Then your dryer will stop heating. You will find the cycling thermostat on the element shoot. It's round, has two screws and two wires going to it.
Please rate solution
Posted on Sep 07, 2009
Electric lift stopped 2/3 way up. There was also a burning smell. Won't work at all. Is there a manual overide?
Hello;
My name is Peter. I am a retired field service appliance technician.
There is no manual override on your dryer. Which is a good thing.
You do not want to run your dryer at this point.
The burning smell is burning lint. Your dryer is plugged up with lint. This is a dangerous situation. You could burn down your home.
Your dryer will not run because the dryer fan will shut down if the air flow is obstructed.
You have a hot air exhaust manifold where the hot air goes into a round bottom inlet up to a expanded hot air distribution headed into the dryer. This is usually plugged up.
This may also have caused the fuse to blow, a operating switch or high temperature limit switch to fail.
Go into the following website and put in your model number. You will get diagrams and component part numbers. Your model number is located on a label either on the face of the dryer when you open the door or on the side of the door.
Water Filters Lawn Garden Appliance Parts
Mar 10, 2016 | Dryers
Won't Spin Drum
The problem could be a list of things . Let's start checking the belt , it coul be that the belt is broken or something is keeping it from doing its job ( a piece of clothing coul be stuck) due to the burned rubber smell you detected. It coul also be the electrical door switch and After checking the three first steps then comes the motor part lets hope is not . Good luck
Nov 20, 2013 | Maytag Centennial Series MEDC300XW
Loud banging sound when dryer is on much like when tennis shoes are drying, smell a burned rubber smell when door opens
Sound like either your belt or your bearings. Either way, I wouldn't run it anymore until I got a professional appliance repair guy out to check it. We wouldn't want your house to burn down. Very dangerous!! I would also unplug it until then as well. Good luck and stay safe!
Jan 28, 2010 | Whirlpool Dryers
My kenmore 90 series dryier is giving off a smell of burning rubber and is very noisy
Bearings are going out on the motor that turns your dryer. The burning smell is possibly the lubrication leaking into the hot motor.
Dave
Jan 13, 2010 | Dryers
Dryer quit getting hot
I would suggest that your thermostats/cut-outs have gone as a result of overheating .. Also replace the door switch as this is a safety device to stop the drum from rotating whilst the door is open
Aug 25, 2009 | Kenmore Dryers
Overheating/burnt rubber smell
classical sign of a bad motor. the motor has a thermal switch on it telling the unit to shut off when it gets hot. after it cools down, the switch will tell the motor to turn back on again. good luck, i'm pretty sure that's your problem. contact me for further help if needed. thanks :)
Jul 06, 2009 | Kenmore 73952 Gas Dryer
Burning rubber smell and the dryer will not turn on
sounds like you need a new belt for your dryer, the smell of burning rubber is the belt slipping, thats my guess
Feb 09, 2009 | Dryers
Dryer stopped working after working w/door open or closed
Sounds as if the door switch/latch had stuck.the smell was probably a small short. try unplugging unit. But I would imagine you need door latch/switch replaced
Feb 06, 2009 | Malber TD700 Electric Dryer
My dryer in my stackable washer/dryer quit
I Think the belt got binded on the motor spindle and the burning smell was the belt burned through by the spinning spindle
Mar 23, 2008 | Dryers
Open Questions:
Dryers Logo
125 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
