Question about SanDisk 2GB microSD Memory Card
I use 2 GB SD cards in my Canon SD500 digital. Some friends have told me I should be formatting these cards before use. I have never done this and all seems to be OK. Is there an advantage to formatting or is it no longer an issue? Thanx, Ray
  • 227 Answers
Well when you fromat the storage device it completely wipes out all info on the drive. By just deleting the photos off once you are done there is still bits of info left behind. You actually gain more storage after a fresh reformat then if you just delete photos. But if you don' feel like formatting thats ok it won't hurt anything.
Posted on Sep 06, 2009
Testimonial: "Very rapid response to my question and right on target. Great help in answering my concerns. Thanx "
You should only format the card in the camera, never via the computer through a card reader. Just through the camera's menu. I don't remember the exact reason but it regards the way the camera formats it is exactly the way it knows to read it whereas when a computer does it, it doesn't do it specifically the way the camera needs to use it.
Format memory card
See page 26 of this manual: http://gdlp01.c-wss.com/gds/0/0900011260/01/PSSD500IXUS700CUG-EN.pdf.
Make sure you're using an SD card, 2GB or smaller. The SD500 will not work with higher-capacity SDHC cards.
Aug 26, 2013 | Canon PowerShot SD500 / IXUS 700 Digital...
I have a canon ixus 700. i've tried to insert a new SanDisk 4 GB memory card. the menu says the card is locked when (i've treble-checked) it definitely is not locked. i read from others that...
According to the specs on Canon's web site, the IXUS 700 works with SD cards, not SDHC cards. SD cards are limited to 2GB in size (there are rare 4GB SD cards, but they tend not to work in SD devices).
Of course, it's your call as to how definitive any manufacturer's web site touting their product might be.
Jul 20, 2011 | Canon PowerShot SD500 / IXUS 700 Digital...
Purchased 8 gb microSDHC Card with adapter for my cannon SD500 & WHILE TRYING TO FORMAT memory card GET AN ERROR saying card locked. I've moved the slide tab to the UP position but continue to get card...
The SD500 uses SD cards (and by extension, microSD cards). SDHC and microSDHC cards are electronically incompatible. While SDHC cards and microSDHC adapters will fit into the slot, they will not work in SD devices. This is a hardware issue and cannot be updated by firmware. You need to go with SD (and microSD) cards, 2GB and smaller.
Nov 15, 2010 | Cameras
My canon powershot SD500 elph's card is locked..one solution someone suggested was to slide the little slider on the side of the card. This card doesn't have that. I put these pictures to my computer but...
Maybe you could try to format the card in the camera. If that doesn't work, try formatting it in the computer. (The card alone, not the camera connected to the computer) Otherwise I think it's broken. Do you use a micro/mini SD adapter? If the contact is bad, it may tell you "Memory card error" and "card locked" at the same time. Check the contact.
May 21, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
Sd card
Sorry, but your camera was designed before the 4GB SDHC card came out. Although they look exactly the same as a standard SD card, they are not. Your camera can only use standard SD cards (2GB or less).
May 12, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
Sd card
There are regular SD cards and high-capacity SD cards (HCSD). Some devices are not compatible with HCSD cards. It sounds like your camera is not compatible. You may still be able to purchase 2G & 4G regular format SD cards that will work fine.
I hope that helps.
Mar 20, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
Asking what to do?
8 GB is more than your A540 can handle. You can check with Canon, but I'm pretty sure that the max that your camera will understand is 2GB. Additionally, your 8GB card is most assuredly an SDHC card and not a standard SD card. Your A540 also does not understand SDHC format. The max card that you should buy for that model camera would be a 2GB standard SD card. These are very inexpensive these days and run about $6, shipping included:
http://www.amazon.com/s/ref=nb_ss_gw?url=search-alias%3Delectronics&field-keywords=2gb+sd+card
Jan 20, 2009 | Canon PowerShot A540 Digital Camera
Formatting a 4GB SD card for my canon ixus 700
The IXUS 700 works with SD cards, 2GB and smaller. It will not work with higher-capacity SDHC cards. You need to use SD cards, 2GB and smaller.
The IXUS 700 is called the SD500 in some parts of the world. You may download the SD500 manual and more from here.
Jun 24, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Jpg files corrupt
After you've donloaded your pictures, have you tried formatting your card in the camera? Press the Menu button, then go to the settings (tools) menu. Go down to the Format option. Select "Low Level" format if available in your menu. Again make sure that you have downloaded your pictures first as this will also erase your card.
If the above doesn't work, have you tried using an SD card reader? If so, the next thing to try would be a different card reader. And finally, have you done a recent sweep for spyware on your computer. Spyware can cause temporary hangup/hiccups that could potentially corrupt your download.
May 27, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
SanDisk 2GB microSD Memory Card Logo
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
