Question about Maytag Neptune MDG5500AW Gas Dryer
What does message 'PF' signify after dryer stops in mid-cycle? Started a small load to dry, and after about 5 minutes, dryer stopped and message PF appeared in digital readout in the estimated time window
  • TomZS May 11, 2010
    it means Power failure restart it and as long as it runs through Ok you are fine could have been a flicker in power,It's an electronic control if the voltage dips below 108 volts it resets and gives you a PF code.
    President:
  • 1,776 Answers
This error code indicates "power failure" was detected. This could be caused by a bad/loose connection at either the logic board, the relay board, or at one of the three main power connection terminals on the back of the dryer. The logic board is located inside the control panel. The relay board is located in the base of the dryer. You can unplug and reseat electrical connections at these locations and check the main power cord hook-up at the terminal block. Also check the thermal fuse and test it for continuity. A lack of continuity means a faulty fuse. Hope this helped and best wishes.
Posted on Sep 06, 2009
Why does it consistently stop 10 minutes into drying cycle and display PF error?
Start with power. Try using a different outlet or extension cord to eliminate your outlet as a problem. examine your cord, look at the prongs to see any melting. if all ok next step is to look at power coming in to control.
Oct 02, 2015 | LG WD-12126RD Front Load Washer / Dryer
MY DRYER SERIAL NUMBER X073808040 STOPS AFTER 20 MINUTES
Kenmore Dryer - heats & runs but stops mid-cycle - Ask Me Help Desk
https://www.askmehelpdesk.com/.../kenmore-dryer-heats-runs-but-stops-...
Kenmore Dryer - heats & runs but stops mid-cycle. Asked Aug 30, 2006, 12:25 PM - 10 Answers .... Unfortunately it shuts off after a few minutes, I'll estimate about 5.After waiting about 30 minutes, ... New Member. Jun 16, 2010, 09:20 AM ...
Sep 15, 2015 | Dryers
How to fix dryer that will spin but not dry
STOPS MID CYCLE AS IF AROUND 20-30 MINUTES? IF SO U MAY HAVE BAD MOTOR WINDINGS? OH OH, CAN CHECK HEATING ELEMENT AND THERMOSTAS WITH A MULTIMETER FIRST
May 12, 2014 | Frigidaire AGQ6700F / AGQ6700FE Gas Dryer
GE dryer stops mid-cycle. If I try to restart it, it won't. Once I wait a few minutes for it to cool down, it will restart. I never know how long it run till it stops. A load last night stopped at...
I would say thermal fuse, here is a website that will tell you how to check, it also has other possibilities, Hope This Helps Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Oct 21, 2010 | GE Dryers
My dryer has been difficult to start lately especially if stopped mid cycle. The lights are all on but it won't start up. Today I only used it 2 times and it was very difficult to start after pressing many...
You may be experiencing "Heat Retention" by stopping your dryer mid-cycle, which you should NOT ever have to do! If you have a minor vent restriction or if you open the dryer mid-cycle when the heat is on, this will cause a disruption in the airflow and rising temperatures can keep the dryer from restarting until it has been cooled long enough.
Check your vent all the way to the outside for restrictions/obstructions every 6 months. Clean your lint filter after each load and DO NOT stop the dryer mid-cycle!
Note: Stopping the dryer mid-cycle can also cause severe burns and even melt polyester fibers.
Jul 05, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer stops and flashes E2 failure
Try unpluging your dry for about 5 minutes. Sometimes it just needs to reset itself.
Jan 31, 2009 | Kenmore Dryers
Whirlpool Dryer stopped mid cycle and won't start again
This sounds as if the internal fuse has blown. I am assuming you have checked the breakers as well. The starter switch might be bad.
Dec 24, 2008 | Whirlpool LER4634J Electric Dryer
Dryer keeps stopping - check filter light on
For Sgt 48 - You are not reading the original message very well - The original help question didn't say they saw check filter at the beginning or end of a dry cycle they indicated that the dryer STOPS MID DRY and says check filter - this is not a friendly reminder, it is indicating something is wrong and the filter needs to be completely cleaned out (and past the filter down in the interior of the dryer) and if that does not work then you need to also check the dryer hose for kinks, lint build up, etc. Lastly, reset the dryer by unplugging it (or flipping the breaker) for a minute or so and hold down on the start/pause button for 8 seconds while it is unplugged (this will reset the error code for check filter, among other things).
May 13, 2008 | LG DLG2525S Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
152 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
