Question about Car Audio & Video
I have a ripspeed cd/dvd player in my car and when you try putting either in it wont take it into the console. you can hear it wanting to draw it in but even if its pushed in further it wont go all the way and gets jammed and in case you ask no theres not a cd already in there ive checked that!! many thanks dan
SOURCE: WONT TURN ON!!!!
Why don't you just take it to Best Buy2.gif or where ever you got it from and then exchange it or you could return it and git your $ back!!!!!!!and rate this Fix Ya please!!!!!
Posted on Dec 26, 2007
  • 111 Answers
SOURCE: Kenwood DDX 7017 bypass code
During code request mode:
Point the remote control to the screen and input this numbers (from the remote control) as faster as you can 55222277
You will not see any change on the screen until you enter the last number.
This will clear the code
If you make a mistake,just reset the unit and start from the top.
Thank you for rating
Posted on Feb 09, 2008
hogan doan
  • 227 Answers
SOURCE: My car dvd player wont eject dvd's or take them for that matter.
Sound like yor unit load/eject mechanism is bad, take it to a local shop if it fixable then it would cost around $100. Call me I know e few dependable shop. 801-414-4566.
Posted on Mar 08, 2008
SOURCE: screens not working
whats a lead?
Posted on Mar 09, 2008
  • 10 Answers
SOURCE: lanzar model SD43MU(( dvd/cd player wont work not funtions for that wont even appear?
I have a similar Lanzar unit. I had it in twice while it was under warentee for the same issue. I also had it in a couple more times for other issues. It cost me about $30 shipping both ways each time I returened it. About a month after the warentee expired, the DVD quit ejecting again.
Bottom line, I would look at purchasing a different uint or use an ipod instead of the CD.
Posted on Apr 21, 2008
Ripspeed dv740 manual
You have not said what the make and model are. If this unit is not mounted in a dash or someplace like that, you can take it apart to remove the cd. If it is mounted and you dont want to unmount it, then you can try to be the CD out with something like a butter knife.
Mar 31, 2014 | Car Audio & Video
Hi don't have a vid i have a ripspeed dv720 it will play CDs but not DVDs it keeps coneing up bad disc any ideas
ripspeed are prone to problems, just a cheap equivelent for an in car dvd, most likely the laser is goosed
Feb 05, 2013 | Car Audio & Video
I need a ripspeed dvd 733b manual
You may download a copy of the manual here.
Dec 15, 2012 | Televison & Video
TOYOTA MR2 RADIO OLD ONE OUT NEW AUDIO IN BUT PLUGS FOR SOUND WONT WORK ? ripspeed dvd player
did the old one work ok?
If its a JDM you'll need a covnertor plus to plug the cd player in if its UK you wont.
Mar 21, 2010 | Car Audio & Video
I need help wiring a sub to a ripspeed dvd-730 cd player.because it has to aux-in wires but 1 sub out wire.
the phono out is the feed to the sub, if your amp has high input socket then run feed from normal speaker feed from head unit, or pop into halfords and ask the ripspeed specialist
Dec 22, 2009 | Car Audio & Video
The door wont open for me to put in the dvd on our player
Put your ear against the dvd draw and press the Eject button, if you hear a noise of a motor spinning up then the belt is either worn so its slipping or has snapped, if you hear no noise then the disk tray loading motor or the driver chip on the mainboard has shorted out.
hope ths helps.
regards jon
Aug 22, 2009 | Daewoo Televison & Video
Instruction manual and installation manual for ripspeed dv725
fitted the dvd player but no sound could u help
Jun 07, 2009 | Car Audio & Video
Ripspeed in car dvd player
I had a similar problem with mine I have just had a technical fault with mine and the only solution i could find was through halfords. If its under warranty they send it off to their supplier AEL to solve. If its no longer under warranty like mine, they send it off at an initial £60 cost which could escalate if the problem is larger.
Feb 12, 2009 | Kenwood DV-605 Multi-disc DVD Player
Ripspeed dv-725 problem when trying to play dvd it says attention, do not use this function!
Your Player doesn't support DVD/CDs that are burnt on High Speed DVD/CD Recorders. To resolve this, you should either burn DVD/CDs at 4x(DVD) & 24x(CD) or go for a newer, higher end DVD Player.
Jun 25, 2008 | Televison & Video
I have a ripspeed dv920i in car dvd player but it has just turned off and wont come on again i carnt find any one to repair
I had the same problem, HALFORDS sent the unit away to have the firmware re-flashed and now it works perfectly again..... These units were re-called apparently due to problems with the software.
HALFORDS staff may be able to advise you about where the unit can be repaired.
Jun 20, 2008 | Car Audio & Video
Car Audio & Video Logo
484 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
