I have been getting an F1 Signal, cannot use will start ,door loc
I have been getting an F1 Signal, cannot use machine. Icalled 800 # was told there is an issue with the Cabrio and it will be fixed free of charge. Called repair Co they gave me, fella came out 2 days later said he would order the part and return when it comes in. I am still waiting for svc. I am shocked to see rhe hundreds of folks with same problem. (internet).I hope whirlpool will make good on this product,as my husband bought me the best and I don't want to hate it. Gerri Paganelli. Largo Fl.I push start, the door locks water starts for a few seconds, then stops with F1 signal.
    President:
  • 1,776 Answers
This is from a service bulletin. This may be of interest to you. There have been many problems with these machines in this area. Anyway, I sympathize and hope this helps. Best wishes.
CORRECTION:
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 – CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A – C above, and verified that there are no issues
with the air pressure system.
Posted on Sep 06, 2009
F1 signal what is the meaning
Pressure Signal Out-of-Range
F then 1 flashes when the control detects an out of range pressure signal.
* Check pressure hose connection from tub to machine/motor control. Is hose pinched or kinked?
* If F then 1 repeats numerous times after POWER is pressed and the pressure hose connection is not pinched or kinked, replace the machine/motor control.
Whirlpool Cabrio F1 error code - NOW A RECALL ISSUE! model # WTW6600SW2 Call Whirlpool or a repair center. The number for Whiripool is 1-800-253-1301
Hope helps.
Jul 12, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My whirlpool cabrio washing machine keeps giving me an F1 ERROR when it goes to the rinse cycle. It will complete the wash after i hit cancel reset and wash. Any ideas?
F1(F68)-Pressure Signal Out-of-Range
I telephoned Whirlpool at 1-800-253-1301. Whirlpool acknowledged the F1 fault and will send a serviceman, free parts and labor, to correct the problem concerning the "famous" F1 fault. This is even for washers out of warranty! This concerns model WTW6600SW2 washers. Be sure to get the authorization code from them so the service person cannot argue about costs.
Jan 05, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 in time remaining window
The "F1" error code on the Whirlpool cabrio is quite common, and generally has to do with the control board. Replacing the control panel may resolve this issue. However, I believe Whirlpool is aware of the F1 issue with the Cabrio, and is fixing some machines for free. Please call 1-800-253-1301 for more details and see if you are eligible for a free repair.
Thank you !!
Jul 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
ERR LOC on display
Your door lock switch needs replacing.
Jul 07, 2010 | Frigidaire GLTF2940ES Front Load Washer
When start is pressed ERR LOC displays, door
You can try clearing the code and then running the machine. Try colding down the pause and clear button simultaneously for three second s and the faul should clear Or try turning the knob around 9 times to clear the fault.
Jan 08, 2010 | Frigidaire ATF6000ES Front Load Washer
My Whirlpool Washer Cabrio model# WTW6200SW has a F1 error (fault) code? Does anyone know what this is and how to clear/reset the code?
Called 1-800-253-1301 was told by the Whirlpool agent that there was a quality issue associated with the F1 fault code. They would take care of parts and labor free of charge! My machine is 28 months old. Talked to a woman named Valerie.
Mar 18, 2009 | Whirlpool WTW6400SW Cabrio Washer
MY fridgadaire lg washer says loc and wont let the door lock and machine start
That is a door lock malfunction, check the lock and wire harness connections.
Oct 12, 2008 | Frigidaire GLTF2940ES Front Load Washer
Recall on kenmore oasis
I have one of the first kenmore oasis and I get the F1 and off balance error all the time I called the recall number line is 1 (800) 659 7026 they said that they are doing a free upgrade to replace the control board the only problem is the board is on a back order and it may take a week to get the part in.
Jul 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Frigidaire washer will not start. Get err and LOC codes.
All the lights are on, but the door lock. We have unplugged it, doesn't help. Our washer is the front load, model LTF 2140ES0.
May 18, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
LOC error
that can be the door lock with out knowing more its hard to say
Apr 05, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
112 people viewed this question
Top Washing Machines Experts
