Question about Garden
Tractor engine won't turn off even when key is
Why tractor engine won't turn off even when key is turned off? I had to finally pull the spark plug cable to stop the engine.
  • Anonymous Mar 12, 2014
    Engine turns over good with spark plug out.
  • 474 Answers
Check your ground wire
Posted on Sep 07, 2009
Huskee madel 13af673h131, won't crank
I guess you were sitting on the seat while trying to start the unit, so Try to apply power direct to the starter, if it turns over buy a solinoid. If it doesn't the starter may be bad. To check the engine: take out the spark plugs and try to turn over the engine from underneath by hand, using the pulley. This will tell if the engine is siezed up
Apr 10, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Why won't my starter turn my engine fast enough on
bypass the battery cables with jumper cables if there bad they will not carry the amps needed to crank it
Apr 23, 2012 | Briggs & Stratton Garden
Turns over but won't start
see if your getting power to the solenoid on the bottom of the carb
Apr 15, 2012 | Garden
My Husqvarna YTH2348 tractor won't start. Nothing
It could be a couple of different things. A couple of things that you can check yourself before having to take it to someone to look at it:
1. Open the hood and try turning the engine by spinning the round "cheese grater" looking part that is attached to the flywheel. - it probably won't turn.
2. Remove the spark plug(s) and try again. (Be careful, if the the cylinder is full of gas/oil it will come out as you spin it by hand.) - DO NOT use the electric start to try and turn it over! This sends spark to the plug wire and could ignite any fuel causing severe burns and/or other serious injuries.
-IF-
You were unable to spin the engine over by hand without the spark plug(s) in it, then you may be dealing with anything from a wedged starter gear to a seized engine. Fuel with ethanol added to it attacks the rubber/neoprene seals in carburetors and often times allows fuel to fill the crankcase and cylinder. If this has happened the above mentioned plan of action will let you know. As always, anytime the fuel mixes with the engine oil, you should change the oil to prevent the engine from locking up under normal operation.
I hope this gives you a little bit direction. =)
Dec 23, 2011 | Husqvarna Garden
My generator will not start I don't think I am getting a spark?
To check the spark you need to remove the spark plug. Then reattach the plug wire to the plug. Next, ground the plug to the engine. Finally, pull the start cable and check for spark. Remember not to pull the starter without the plug being grounded or you can ruin the ignition module.
Aug 26, 2011 | Garden
I just put a new carb on my 17.5 hp lawn tractor .... it starts and runs great then after about 2 minutes it cut out .... and won't start for a few minutes .... spark is good ...... any ideas? it is...
It is possible that the fuel line is too close to the engine and the fuel flashes to vapor in the fuel line causing vapor lock. I recommend adjusting the fuel line if posible, and retry. Maybe replace that section of fuel line.
The other possibility is the ignition coil is going bad. You can check it by running the engine and when it stops, quickly remove the spark plug, caution hot. Put plug back into the wire and ground the spark plug and try to turn over the engine with the key start, if good spark, then the problem is likely the other,
I mentioned the fuel line first, because you said that you had been working with the carburetor, and the fuel line may be moved or a little shorter.
I hope this helps you get going soon.
Aug 16, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Hi, I have a Craftsman LT1000 lawn tractor and yesterday while I was cutting down some really tall weeds it suddenly shut off on me. When I turn the key now, even with a jumper cable from my car to the...
first thing to do is pull your plug put the plug back in the wire hold it close to the metal block and turn the engine over and see if theres any spark
Jul 24, 2011 | Craftsman Garden
Sprayed down lawnmower with water, now it won't start. I decided to "wash" the lawnmower last week and now it won't start. And the really weird part is the solenoid clicks every minute...
Engine will not run with no spark or a weak spark. Continuity test will only reveal that the winding is not open, not if you are producing a weak spark that will not jump the spark plug gap.
Mar 31, 2017 | Garden
New 12hp tecumseh engine won't fire
IF THE ENGINE WILL TURN OVER WITH THE KEY YOUR PROBLEM LIES WITHIN THE ENGINE ITSELF
PULL THE SPARK PLUG AND LIE IN ON A GROUNDED SURFACE WITH WIRE ATTACHED TURN ENGINE OVER AND VISUALY CHECK FOR SPARK
IF STILL NO SPARK YOU WILL NEED TO PULL FLYHEEL TO CHECK POINTS AND COIL
IF YOU NEED ASSISTANCE IN THESE PROCEDURES LET ME KNOW
Sep 19, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
