On a 1996 Buick Century, 3.1L V-6; the AC clutch doesn't spin with the AC set on Max. What to check?
  • 432 Answers
If the system is low on freon the clutch wont come on. It should have a low pressure cut off switch (this could also be worn). Also you can check for 12 volts at the wires going to the compressor when you have A/C set on. If no 12 volts it should have a fuse to check also.If it has 12 volts and it (the compressor clutch) does not ingauge it needs replaced.I hope this helps you.
Posted on Sep 06, 2009
Testimonial: "Very kind of you to take the time to reply. Great places to start. Thank You Bret"
HOT PLUGS FOR A 3.1 bUCK cENTURY
Buick Century Spark Plugs - Spark Plug - NGK AC Delco Denso Bosch ...
www.partsgeek.com > Spark Plugs > Buick Spark Plugs > Century Parts
99 1999 Buick Century Spark Plug 3.1L V6 NGK TR55IX NGK. Click to Enlarge. (Read reviews). Product List Price: $19.42. Our List Price: $10.48. Quantity:.
Buick Century Spark Plugs & Glow Plugs ' eBay
https://www.ebay.com > ... > Buick Century Spark Plugs & Glow Plugs
Results 1 - 25 of 13351 - E3 Spark Plugs E3.44 Spark Plug (Fits: Buick Century) ... 6 pcs NGK V-Power Plug Spark Plugs 89-05 Buick Century 3.3L 3.1L V6 Kit Set ...
Buick Century Spark Plugs Glow Plugs ' eBay
https://www.ebay.ca/sch/i.html?_fsrp=1...Buick+Century...Plugs+Glow+Plugs
Find great deals on eBay for Buick Century Spark Plugs Glow Plugs. ... Iridium Plug Spark Plugs 94-05 Buick Century 3.1L V6 Kit Set sw (Fits: Buick Century).
1995 BUICK CENTURY 3.1L V6 Spark Plug ' RockAuto
www.rockauto.com/en/.../buick,1995,century,3.1l+v6,1016121,ignition,spark+plug,721...
RockAuto ships auto parts and body parts from over 300 manufacturers to customers' doors worldwide, all at warehouse prices. Easy to use parts catalog.
hOT PLUGS FOR 3 1 bUCK cENTURY Google Search
Jul 27, 2017 | Cars & Trucks
How do u get ac compressor to engage in a 96 buick century
When you turn it on, the power goes to the clutch through a fuse and a low pressure switch, check the fuse in the fuse block and then make sure you have Freon in the system, if it is low, the unit wont start.
Mar 18, 2017 | 1996 Buick Century
2000 Buick Centry AC R134 pressure ok Compressor kicks in on demand, no cool air?
If you have a set of manifold gauges, check the pressure prior to starting the engine and see if you are somewhere between 80 and 100 psi. If so, start engine and then turn on A/C to 'max'. Hi side may rise to as high as 350psi with the low side dropping to around 40psi. Feel the low pressure line going to the filter/dryer and see if it begins to get cold. If it does not get cold, trouble shoot your compressor and expansion valve. If it does get cold, your cooling system is working and you need to focus your attention on the blend door mechanism under the dash. These cars use a 'stepper' type digital motor to close off or open the pathway in the airbox to direct the flow of air through the heater core, or A/C evaporator core depending on if you are wanting hot air or cold air respectively. In either case, if the blend door is not properly actuated, you will not receive any cold air into the cabin. The actuator is available at: http://www.partstrain.com/store/details/Buick/Century/Dorman/A-fs-C_Actuator/2000/RB604107.html?source=productads for about $30.
Aug 31, 2012 | 2000 CENTURY A/C Compressor a1z29069...
When I turn on the ac or heater I notice that my engine starts making a funny noise. When I step on the accelator it sounds like a pulley is making a strange noise
you may have an a/c compressor clutch and or clutch bearing going bad. may be time for a new a/c compressor or compressor clutch assembly. the a/c comes on when you have the defrost or recirculation on in heater mode.
May 30, 2011 | 1996 Buick Century
I need the firing order of a 1996 Buick Century 6 cylinder.
Here are firing order diagrams to help assist you, and let me know if you require any further assistance.
Nov 24, 2010 | Buick Century Cars & Trucks
AC blowinghot air
Locate wires coming from compressor clutch and trace to nearest plug that you can unplug. Turn on A/C to max cooling. If clutch not engaged (center of compressor drive pulley not spinning with pulley), unplug compressor clutch wires and use multimeter to check voltage going to compressor clutch. If voltage is around 12 volts or more, then clutch should be engaged when plugged in. Plug clutch wires back in (with motor still running and ac set to max). If clutch still not engaged, then clutch definitely bad because 12V signal should engage it.
May 08, 2010 | 2002 Lincoln LS
1996 buick century, I had a tune up and egr valve
Have an auto parts store check for the code. It is possible that you have a bad O2 sensor or your catalytic converter is clogged.
Apr 10, 2010 | 1996 Buick Century
4T60E transmission in a 1996 Buick Century won't shift from 2nd to 3rd gear, possible cause?
Shift solenoid ,manual shift valve, blockage in 3rd gear circuitry, defective band and clutches.
Mar 31, 2010 | 1996 Buick Century
AC does not engage when turned on
Take the glove box out. Behind the fuse box you will find a big gob of black tape, (it looks like a box shape all taped up. Take the tape off and you will find three inline fuse holders taped together. The AC fuse is the 10 amp one.
Sep 28, 2009 | 1996 Buick Century
Air conditoning gets warm at idle. 1998 buick
It seems the automatic idling lifter (sensor) once you switch on the a AC system has failed and thus at low idling the Ac compressor clutch gives in stopping the compressor to spin.
You have to check tht system out.
Hope this helps!
Aug 04, 2009 | 1998 Buick LeSabre
Heating & Cooling Logo
97 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
