Question about Dishwashers
How to remove the drum on a kenmore dishwasher model #16529000
  • jennasgifts Sep 06, 2009
    I think I stated the last question wrong, we are trying to remove the impeller for a kenmore dishwasher model #16529000. Thanks Jan
    Genius:
  • 1,689 Answers
Why do you need to remove it? im still looking for a good illustration, while im still looking, let me know what you need as i may be able to help out.
http://dl.owneriq.net/f/f08c0fe5-1218-4765-969f-79e12e0d859f.pdf
Posted on Sep 07, 2009
  • 3,230 Answers
First of all you need to remove the top panel and each fin has 2 5/16 screws holding them to the drum. turn the drum so the fin is on top and remove the screws then remove the coins, do vice-versa after removing the drums to install new one.
post further comments for more information ....
Thanks
Posted on Sep 06, 2009
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
Kenmore Model 587.15103800 dishwasher won't drain
dip water out take pump apart remove debris look for broken blades if so install pump kit thumbs up
Aug 11, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore Dishwasher Model 15145 will not drain
Discharge pump is clogged. Not a fun job to remove,
Jun 27, 2009 | Dishwashers
My dishwasher kenmore 16529000
When you move the float up and down do you hear the click of the switch? It is real faint but noticeable. If you removed the float to clean it it may not be contacting the switch. When did it stop working? There is a thermal fuse for over heat protection and if that is blown it has to be replaced and the reason it blew fixed.
Eric
Jun 08, 2009 | Kenmore 63942 Dryer
Water keeps coming back into dishwasher after cycle is done
sounds like maybe one of your check valve is not working right.
Jun 03, 2009 | Dishwashers
Kenmore Elite 137889, grinding noise
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the tub.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
The drum bearing is replaced by accessing the bottom side of the washer, and is a not a simple repair.
May 05, 2009 | Kenmore 13789 / 13782 Dishwasher
Water not draining and not clean
When dirty water is left in the dishwasher the pump assembly is a primary cause. To assure that the dishwasher gets fully repaired and you are going to do the work yourself, I would order and install this part:
http://www.repairclinic.com/SSPartDetail.aspx?s=t-16529000-%3d%3dc261i1065702&PartID=1065702
Also, check that the heating element is working. Many people replace the heating element whenever they replace the pump/ motor.
Good Luck!
Mar 27, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
MAYTAG DISHWASHER STUCK WITH LIGHT BLINKING
Try holding down "Heated Dry" for about five seconds, until the light switches off. You should be good to go.
Oct 20, 2007 | Kenmore 15129 Built-in Dishwasher
Vent cover removal from Kenmore 17252 dishwasher door, for cleaning
kayzy If you remove the bottom kick panel you'll find the pouch with technical data on the inside part of it. You will find a complete instruction how to remove the vent. Gendos...post back
Feb 06, 2007 | Kenmore 17252 Free-standing Dishwasher
Dishwashers Logo
18 people viewed this question
Top Dishwashers Experts
