Question about Sony Playstation 3 (PS3) Console
Hdmi I have just bought ps3 . I have 2 yr LG tv and got a hdmi cable but it just wont connect to telly when playing blu ray dvd's. No Signal keeps coming up. Have tried through video output already. So frustrating...help please.
  • Anonymous Jan 18, 2009
    when i hook it up it just says invalid mods on my tv.is it my tv or my ps3
  • 4 Answers
This worked for me:
After hooking up the HDMI cable and getting nothing, I used the AV multi cable that Sony supplied with the console - it has regular old composite cables (3 RCA's - 1 White, 1 Red, 1 Yellow). I set the TV input to Video 1 (or whatever input is appropriate for the composite cable connection). I was able to see the PS3 menu now - I went to the PS3 Video settings and selected HDMI as the input type - the disconnected the composite cables. It worked for me.
Posted on Jan 18, 2009
    Problem Solver:
  • 4 Answers
I can't be exactly sure without more information, but it sounds like you ps3 is outputting from another port. My ps3 originally was outputting from the component/composite cable port so in order to use the hdmi output I had to do a soft reset. That makes the ps3 sense what cable is plugged into it and automatically output through that port instead of using whatever is the saved setting.
With your ps3 turned on hold down the power button for a few second until it beeps and flashes 3 times (should be about 5 seconds). You might have to try it a few times to get it to work, but you should get picture and be able to adjust the settings on the ps3.
Posted on Dec 08, 2007
How do I get my Samsung Blu-ray player to work on my TV it says unuseable signal
sounds like your blu-ray is outputting a higher signal then your tv can handle. for instince your playing is outputting in 1080p but your tv is only 720p that or your hdmi cable is not makeing a good connection. you can get a hdmi cable on ebay for $0.99 with free shipping.
Feb 19, 2016 | Samsung Televison & Video
How do I hook-up Netflix through a Sony Blu-Ray player and a LG television
If your Sony Blu-Ray player and LG TV are recent models, each should have an HDMI cable connection. HDMI is an method to connect your digital video and audio devices with just a single combined cable. In the case of your LG TV, using an HDMI cable will allow you to send the HD video signal to your TV's screen, and allow you to hear the sound through the TV's speakers.
Your LG TV may have multiple HDMI connectors, to allow other devices to send signals to your TV, such as a cable box or satellite box or digital video recorder (DVR). Your Sony Blu-Ray player will usually have just a single HDMI connector.
Purchase an HDMI cable from your local electronics store. There are different versions of the HDMI specification, and you should get a cable that you can verify is certified for the HDMI version 1.4 specification.
Plug one end of the HDMI cable into the Blu-Ray player, and the other end into one of the HDMI connectors on the TV, noting which one you selected.
When you turn on your Sony Blu-Ray and your LG TV, you should use the remote for the LG TV to select the input source. Your LG remote should allow you to select the HDMI input connector you used, at which point you should see the display of a DVD playing on the Blu-Ray player. If you cannot hear the sound, use the LG remote to increase the TV volume.
Mar 02, 2015 | Netflix
Why wont my samsung dvd-vr357 play blu ray disks
Educated guess is you need a blu ray player. I have several very expensive Pioneer Elite DVD players and they cannot play blu ray. Blu ray is a multi level glorified DVD which you need at least a blu ray player to play in almost all cases.
You can play dvds on a blue ray but not the reverse in most cases. If you play a dvd on a blu ray player it kicks the video up to HD for the DVD.
Apr 14, 2014 | Televison & Video
Player turns on ok,display shows menu that disc is playing but tv says there is no signal, not seeing home screen with net flixs or the other apps.player has been working great we used it 2 day earlier...
The "handshake" between the television and the blu ray player has been lost. This happens a lot when connecting with hdmi. Sometimes a hot swap will work to remedy this. That is turning off and unplugging both your television and bluray player while removing the hdmi cable from both for 30 seconds to one minute. Reconnect the bluray player to the hdmi cable and then to the television. Plug them both back in and turn the television on first then the bluray player. Your television may need a factory reset going into the service menu or the board the hdmi ports are located on might need to be replaced if all of the hdmi ports are not responding. You can connect with component if possible in the meantime.
Apr 14, 2011 | LG BD390 Blu-Ray Player
Just bought the sony bdp s350, bought the cable
What type of TV? Plasma / LED / LCD.. ?
Typically you should run through your HDMI ... most of the 5 RGB etc.. in the back can only be used on one of the inputs only for high def... HDMI is easier but more expensive cables..
May 12, 2010 | Sony BDP-S300 Blu-Ray Disc Player
My Sony Blu-ray DVD player isn't working with my LG HD TV
needs a HDMI™ (V1.3), tv set , or above. try to check the lg tv set is compatible to HDMI™ (V1.3).
Feb 19, 2010 | Sony BDP-S350 Blu-Ray Player
I tried connecting HDMi cable from player to TV
You may have a defective HDMI cable. If you have a friend with a working cable you could test yours on their system.
Dec 29, 2009 | Sony BDP-S300 Blu-Ray Disc Player
PS3 not working on 42'' JVC via HDMI cable port
I have the PS3 and this TV and it works....Try this.
1. Turn ON TV
2. Connect HDMI from TV to PS3
3. Select the correct HDMI input on the TV for the PS3(important)
4.Turn OFF PS3 if it is ON.
5. hold [I/O] Power button on PS3
6. Wait about 5 second and you should get the "HDMI Detected" or some similar message.
7. Configure the HDMI output for the PS3
Also, If you set the PS3 to "auto" for hdmi, it may set the resolution to 1080i. You may want to deselect everthing but the 1080P.
Mar 24, 2009 | Sony Playstation 3 40GB System Console
42LG50 TV - Intermittant sound problems with blu-ray HDMI input
You say this doesn't happen on regular cable or when playing a regular DVD. Hmm. Is this Blu-Ray player connected by simplink? HDMI is a bi-directional format cable, so  there are cases in setups where your tv can send commands to your blu-ray player and vice versa. It could be a problem with your blu-ray player that it is sending for some odd reason a mute command to your tv. Or is processing a command that your TV interprets to be a mute command when playing blu-rays. Because if it was the TV itself chances are you'd see this when watching a normal DVD or on cable as well. Since you say you're not, it leads me to believe the issue lies with the blu-ray player itself.
Feb 15, 2009 | LG 42LG50 42 in. LCD HDTV
Sony Playstation 3 (PS3) Console Logo
289 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
