Question about HP Computers & Internet
Need to change and/ or delete parantal control.
Need to change or delete the parental control option on my PC. Not able to gain access to HP Administrator. I know the password but still will not let me in. Can U help?
Whhat OS u have
Posted on Sep 06, 2009
I need to control the access on the internet how do i do this and manage my BT Hub
If by control access on internet in other accounts you could set up parental control and modify settings with time frames when can someone access certain programs. functions are limited in parental control accounts. If BT is refer to Bitorrent - usually BT software on preference or options have the option to allocate bandwidth usually set on "0" which is unlimited - if you set for ex 250 - your limiting your download or upload to 250 kb./s
Oct 17, 2014 | Computers & Internet
How do you see your name and password when you make changes on parental conyrols
For better way to understand the technical details follow https://www.apple.com/uk/support/macbook/ because lot of system have different specification so for more help Mac Technical Support
Jun 21, 2014 | Apple MacBook Mac Notebook
How do I change Parental Control on ROKU?
Parental control is one of the features available on roku. This feature restricts the children to access the movies and TV shows based on the rating of the movies and TV shows.
Roku doesn't provide any true parent controls. But the parental control workaround is simpler one. Only a few channels on roku have the parent control. Such channels are Amazon Instant Video, Netflix, and Redbox.
Initially, you have setup your roku account and add the channels from the channel store by using the PIN.
    1.Sign in to your roku.com/link account.
    2.Click the update button which is next to the PIN reference.
    3.Then choose the choice "A PIN is required when using your Roku account to make the purchase or add any item from the Channel Store."
    4.Put the 4-digit PIN and save the changes. After that, you can watch the channel by installing them from the roku channel store.
    After finishing the watching the channels delete it.
    If you deleting the paid channels means there are no issues because you need not pay again for reinstall. For re-install it you have to sign in again.
    For some channels which have parental control, that doesn't require to delete the channel after watching.
    If you want more information about the roku call 1-844-965-4357 to get instant help.
Apr 07, 2014 | Computers & Internet
I have lost my parental control
First un-install and then reinstall Kaspersky.
This will gain you the access to parental control settings.
Mar 27, 2011 | Kaspersky Labs Kaspersky Internet Security...
I need to cancel my parental control account
If you know the password, then it can be done easily, when you enter the parental control password, it should allow you change different settings..... Hope this helps :) If there is no password, then just go ahead and select different things until you find the option to disable/delete parental controls.....
Jan 11, 2011 | RCA Scenium HDLP61W151 61 in. HD-Ready...
How to reset the parental control code - I forgot the code and want to reset with a new one
This is what I found in the instruction manual on this and I posted it here for you. Try using 3355 for the code and everything else listed here. If that doesn't work, try the very last tip which tells you how to do a factory reset and repeat the first step using the 3355 as the code.
Here's the instructions from manual:
Parental Control
Parental Control allows you to block certain channels or programs so children cannot view
programs that are not age appropriate.
To enter the Parental Control menu, you need an
access code. The first time you enter, use access
code 3355. See "Setting an Access Code" on
page 33 for information on creating a new access
code.
You can set the following options to block
content:
• Channel Lock — Blocks selected channels
• Movie Rating — Blocks movies based on their rating (G, PG, PG-13, R, NC-17, and X)
• TV Ratings — Blocks TV shows based on their rating
• Block Options — Turns on or off all your parental control settings
NOTE: You can use Clear All to unblock the channels and programs that you have set.
NOTE: If the Block Control in the Parental Control menu is enabled, all the sub screens in POP (POP1,
POP3 and POP12) mode will be blank
Setting an Access Code m
After you enter the Parental Control menu for the first time, you can set your own four-digit access
code. If for any reason you lose or forget your access code, you can use the default code.
1 In the Parental Control menu, select Change Code.
2 Using the number pad on the remote control, enter a new access code.
3 Select Exit.
Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset
Jul 28, 2010 | Dell W4201C 42 in. Plasma HDTV
Forgotten parental control password
that easy to fix go to your control panel click on users click on your user profile and u can change password in there if for some reason it wont let you create new profile and set that as admin.and delete other profile and click on save all files and it will fix this problem
Mar 26, 2009 | HP Pavilion dv9000z Notebook
I WANT TO DELETE OPTION FROM 'CENTER' BUTTON TO GAIN MENU OPTIONS
first you selected the right button on your hand and then it will deleted ok you changes the option button in settings
Dec 26, 2008 | Samsung SGH-G600 Cellular Phone
PS2 PARENTAL CONTROL CODE
This is the only way to turn "off" parental control lock on the custom setup screen.
1) turn off ps2 with no dvd in drive.
2) turn on ps2 and insert dvd in drive.
3) when it asks about parental password, choose 'yes'.
4) when prompted for password, press 'select'.
5) the prompt will change and say 'delete password'. enter '7444'.
6) enter a new password (0000 works).
7) registration complete, dvd will start playing.
8) once the movie starts, press 'select'.
9) click the 'stop' icon.
10) click the 'stop' icon again (the icon must be gray even when you have it highlighted).
11) navigate to 'custom setup' ('select', setup icon, custom setup icon)
12) move to parental control option, press right directional button, enter password (0000).
13) move down to 'level'.
14) move up to desired level (off is at the top).
15) click 'x'.
16) go back to 'select' menu options, and press 'play'.
17) while movie is playing, eject disk and remove dvd.
18) turn ps2 off using switch on the back, keep off for five seconds.
19) turn on ps2, put dvd back in.
20) happy dance. ;)
Dec 25, 2007 | Sony PlayStation 2 (PS2) Console
Computers & Internet Logo
35 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
