Question about Technics SC-DV290 System
Technics dv290 system
The dvd/video cd/cd changer SL-DV290 fails to play. it trys to read the discs but comes up with "DVD H02 NO PLAY".
I've had the system about three years and had no problems with either CDs or DVD untill now.
can anyone help.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 99 Answers
I once had a panasonic dvd player which displayed the same code H02 and used the same drive mechanism as your player. this turned out to be a worn spindle motor and once replaced, all worked fine. you may well have the same fault. hope this helps?
Posted on Jan 01, 2010
Hi how do i change from playing dvd to cd?
it will play whatever you put in it automatically, whether it be cd or dvd. it will recognize which disc is inserted and all you have to do is press 'play'.
Jul 03, 2010 | Technics SC-DV290 System
FAILURE TO READ DISCS. TECHNICS SL-DV280 (SC-DV280)
if the disc starts to rotate when helped by hand then you definately have a weak spindle motor. dvds spin faster than cds which gives more wear & tear to the motor. i've repaired these faults numerous times. hope this helps?
May 08, 2009 | Technics SC-DV290 System
It wont read any disks and keeps coming up with DVD HO2 i've unplugged it for a while but it still comes up with the same message.
POSSIBLE solution
I had this problem a while ago comes up with that code then NO PLAY there are 5little discs inside that seperate the discs when theyre inserted these had come loose somehow I simply restacked them on the spindle, however they MUST go in a certain order or H02 will still appear, mine had numbers on them (but NOT consecutive) I just stacked em in ascending order. It worked great after that.
HOWEVER Ive just had the same problem again but the discs arent loose this time.
Mar 10, 2009 | Technics SC-DV290 System
Technics sl-dv 290
I think your dvd is set to a different region. This might help:
1. Insert disk
2.Wait for 'no play'message
3.Immediately press stop
4.It wi go to chapter review automatically in about 5seconds time u should be able to press play and start the movie
Hope this helps
Miss didi
Nov 01, 2008 | Technics SC-DV290 System
Technics sc-dv290
i once had a panasonic dvd player which displayed the same code H02 and used the same drive mechanism as your player. this turned out to be a worn spindle motor and once replaced, all worked fine. you may well have the same fault. hope this helps?
Oct 26, 2008 | Technics SC-DV290 System
SL-DV290 DVD player error message
sl-dv 290u meu refuza sa functioneze. Knd il aprind se aude un barait in boxe si se stinge. Ce pot face pentru a remedia aceasta problema?
Apr 03, 2008 | Technics SC-DV290 System
My Technics SL-DV290 stereo has stopped playing dvd/cds, it just says 'no read' when it initially scans dvd/cd prior to play Please help!
This means that the unit can tell that a disc is present, but can not read it. Try opening up the top and cleaning the lens using a cotton swab and alcohol. Let us know if that resolves the problem.
Thanks,
Dan
Apr 02, 2008 | Audio Players & Recorders
Not playing discs
i have a technics hi fi sc-dv290 when i put a cd in it comes up h2o no play do you know what this means thanks
Jan 12, 2008 | Technics SC-DV290 System
Technics ho2 no play error
u need a new motor in yr dvd player i had same problem so had new motor fitted cost 50 pound works now
Sep 20, 2007 | Technics SC-DV290 System
Technics SC-DV290 System Logo
673 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
