Question about DB Drive Platinum PD1200 Car Audio Amplifier
I need a remote bass control knob for a db drive ph1200.1 car amp? all i can find is the one for the speed amp.
5 Suggested Answers
SOURCE: bass knob
yes, they sell one for around $25-30 w/ the phone cable. do not attempt to use any other brand, they will simply not work.
Posted on Oct 07, 2007
  • 631 Answers
SOURCE: Amp protection light comes on when raising volume...
It sounds like you either have too low of an ohm load or the voltage is dropping at the amplifier's power terminal.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect one speaker and see if it shuts down. If it doesn't, disconnect that speaker and connect the other speaker. If it only shuts down with both speakers connected and the voltage is staying above 12v, the ohm load is probably too low and you'll need to rewire the speakers.
Posted on Dec 31, 2007
  • 4 Answers
SOURCE: I need a remote control bass knob and cable for a Legacy LA590 2
Most of the remote bass control knobs & connectors are the same, regardless of manufacturer. Granted there are different styles & connectors used, but just find one that's compatible with the amplifier you have. You don't state what amp you have (at least I don't see it in desc.) Send me some info & I'll get back to you tonight. Bruce McGowan waterskiers2@yahoo.com
Posted on Mar 24, 2009
SOURCE: I need a bass knob for my crunch amp
i need an bass knob for an planet audio rxd2400
Posted on Nov 11, 2009
Mtx tna251 amp has bass remote that has a light glowing but turn knob up and down and no difference like simply not working no difference in bass? Posible causes,
It is actually in the controller, if you turn the remote all the way down and press on the controller until the bass goes off, you will be able to turn the bass up and down with the remote, mine worked but stopped after a month, I tried adjusting the amp but then I noticed that if I wiggled the knob on the remote that it would work, I mashed mine until it worked again and velcroed it to my console sonibcan get it on and off easily.
Mar 03, 2015 | MTX Car Audio & Video
I have two kicker cvr dual voice coil 4 ohms to a
what about the remote power wire from the radio? 2 channel or four channel(amps)? are the speakers running parallel or in series? are you using a mono block? or an EQ?
Oct 13, 2014 | Car Audio & Video
I dont have the blast port wire and it wont play.where can i find the wire?
  • BLAST Port (Bass Level And Signal Transfer) Provides Remote Bass Level Control and control signal transfer between multiple SX amplifiers
  • Here is the manufacturer's accessory page to the remote: http://www.kicker.com/zxrc
    Here is one on eBay: http://cgi.ebay.com/KICKER-2010-10-ZXRC-AMP-AMPLIFIER-REMOTE-BASS-CONTROL-/360328112100?pt=LH_DefaultDomain_0&hash=item53e53aa7e4
    And here is a note from Kicker on how to make a control yourself for strapping multiple amps together: I have two or more Kicker SX or KX subwoofer amplifiers. I don' t want to use all those separate bass level controls. Is there a way to make them all work with a single Kicker control knob?
    Yes. You can visit your local Radio Shack or home improvement store and purchase an RJ-11 modular adapter. You then plug the sub level cables from the individual amplifiers into the adapter. Then run a cable from the adapter to a single Kicker remote knob. All amps will now work with a single knob.
    Dec 28, 2010 | Kicker SX400.2 Car Audio Amplifier
    ROCKFORD FOSGATE X7a Amp, I need compatiable remote control knob.
    It will NOT work!
    You need p/n AP-3212. If you are in USA then contact Rockford for this part number.
    Aug 11, 2009 | Rockford Fosgate Type RF X7 Car Audio...
    Mar 23, 2009 | Car Audio & Video
    Bass control stopped working
    on rockford amps, the bass control knob needs to be connected to get the maximum output (+18 db gain i believe). If you did this to the power wires, then yes, you may have at least damaged the bass control knob. Try replacing this to see if you get all of your gain back. If not, then you have damaged something inside the amp...maybe a capacitor or power supply inside. If that's the case, you'll need to get the amp looked at by an electronics repair technician or local stereo shop.
    Aug 10, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
    Wired remote bass control knobs
    I'm wanting to know the same thing... But be careful on the pin out of the control you get.
    I have an audiobahn 2300HCQ amp... Before I had the 1800. The 1800 came with a remote with 6pin remote cord. I got the 2300 used and did not get a control for it. The plug on the 2300 is a 4 pin plug... I can't figure out how to cross it over correctly to get the 1800 remote to work on the 2300.
    I have tools to crimp an end... Just can't figure out the color pin out.
    Apr 16, 2008 | Car Audio & Video
    Bass knob
    most amps comes with specific controlls finding a controll will be a little difficult,what knob, is it the one one the amp or the remote one?
    Aug 22, 2007 | JBL GTO1201.1 Car Audio Amplifier
    Bass knob/remote for kac-9152d
    dont try that yet,doesnt require remote to work,only added feature
    Aug 11, 2007 | Kenwood KAC-9152D Car Audio Amplifier
    DB Drive Platinum PD1200 Car Audio Amplifier Logo
    295 people viewed this question
    Top DB Drive Car Audio & Video Experts
    Professor_V
    Professor_V
    L Pfaff
    L Pfaff
    Are you a DB Drive Car Audio and Video Expert? Answer questions, earn points and help others
