Question about Plumbing
Flotec water pump. Our pump is over 4 years old. It seems to work well. Today, we found that after pumping, when the wather is switched off, the last few seconds of pumping which build up the pressure 'jutters', where previously it was very smooth?
  • john97900 Sep 08, 2009
    Water hammer is probably a good description for it. However, it's only just started doing it after 4 years - and since posting this message, it has come and gone a few times.
    Problem Solver:
  • 9 Answers
Sounds like water hammer when water stops flowing abruptly it will "hammer" in the pipe the solution is to have a bounce tube above your faucet this gives the water a place to lose energy.
Posted on Sep 08, 2009
Pressure switch no longer making contact
First try to clean the contact points, maybe it's help
Mar 26, 2013 | Flotec Pressure Switch 40/60 TC2153
We have a flotec well pump, less than a year old. The pump is working fine, and is primed. The switch doesn't appear to be working. Is this a difficult item to replace? Home Depot sells the pump and...
To replace the switch, shut off power, remove wires noting all wire locations.
You may have to relieve pressure in the system by using water until the surge tank is empty.
I'm not sure about that.
You do have to either remove the switch from the piping by unscrewing it or remove the piping from the switch by removing the connector and unscrewing the connector from the switch.
Assembly is the reverse. You should use teflon tape of dope on the screw connection below the switch.
The procedure should take about a half hour but you won't have any water during this time.
Gary
Jul 21, 2011 | Flotec TC2151 P2 Well Pump Pressure Switch
I have a Flotec FP0S1775A Utility Pump. It is in a section of my basement (flat) that is about 1.5 inches lower than the rest. Today is the first day the pump is being used and for the most part it is...
1 inch of water is probably not enough water to set off the pump. The water level must be high enough to float the switch ball beyond 90 degrees of level before it will activate the pump. The pump will not evacuate all of the water there will always be some water left in the tank this prevents the pump from a dry start.
Mar 07, 2011 | Flotec 1/4 Horsepower Sink Pump System
Flotec 1/4 Horsepower Sink Pump System slow to drain. Seems clogged on the sink side of the pump. Can I use Drano or clorox or will that damage the rubber and plastic parts int he pump?
hi, draino and all those sorts of products only make it worse they will help the blockage solidify best way is to run hot water through the system even if it is boiling water from the kettle and a little bit of a pump with a plunger should do the trick
May 27, 2010 | Flotec 1/4 Horsepower Sink Pump System
I have a flotec 47013 and would like to know how to prime pump
you need to fill the hose or pipe with water then put the pump on and it should work.
Apr 01, 2010 | Plumbing
I have a 1 month old Model FPOS1775A Flotec pump. The discharge hose is 3/4 inch with a level run of 20ft.It pumps water but only at 2 and a half minute intervals even when fully submerged!!! I now have a...
If the pump is only pumping for a few seconds at a time it may be a problem with the control board. On two of mine, the 10mf 100v smd capacitor came loose. Resoldered and potted with hot melt glue. One of them is working with the other yet to be tested. Don't recall what the exact symptoms were, only that it wasn't continuously pumping water while submerged.
Unit is oil filled so should be dismantled in the upright position.
Feb 23, 2010 | Flotec 1/4 Horsepower Sink Pump System
I got 1 year old flotec 3/4 hp pump and it take
I have had the same problem there are a few things that can cause it to take longer to shut off, if you are running a sand point well that's usually a sign that the sand point is clogging up,if you have a sistern or a dug well check the screen on the end of the suction pipe,another possible cause is the water level has dropped low enough the pump is having to work harder to pull the water up, you should also check your pressure tank and the points for the pump if the points are sticking the pump will keep running till it builds enough pressure to trip them.Check for leaks in the suction line, if it is sucking air that would cause it to run longer to.I hope these suggestions will help fix the problem. Have a great weekend
Sep 05, 2009 | Flotec Plumbing
I have a Flotec FP 4022-10 3/4 hp shallow well pump. It was working fine yesterday afternoon and then in the evening I had no water. I replaced the pressure switch and checked the pressure in the tank...
If heating up, the motor thermal switch is opening to shut down the motor; this is by design. During the brief run time does it pump at all? It sounds as if there may be mechanical issues on the pump itself and the motor (from the extra draw) is heating up and shutting down. I'd look in to the pump to see if anything had failed within it.
I hope this may have helped,
Tom
Jul 16, 2009 | Flotec Corrosion Resistant Shallow Well...
Schematic for wiring in a Flotec Pump
Remove end casing of Flotec motor housing they have a 115v/220v switch, turn to 220v, see website flowtec water. Flotec parts 1-800-365-6832
Jan 31, 2009 | Flotec Corrosion Resistant Shallow Well...
Plumbing Logo
91 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
