Question about Apple iPhone 3G Black Smartphone
Iphone does not boot after installing mms software from cydia.
Afer restoring from itunes does the crack remains?
How do I jailbreak my iPhone 4s
"Jailbreaking" is a process that unlocks your iPhone 4 from iTunes, allowing you to install software from the third-party Cydia application store. The apps on Cydia do not have to pass through Apple's approvals process, and often offer functions that are otherwise prohibited by Apple's terms and conditions. Jailbreaking your iPhone can be achieved by visiting a website in the device's web browser that automatically installs Cydia, and the operating system changes that allow it to run. Jailbreaking your iPhone is entirely legal and safe, but does void the device's warranty with Apple. Download and install the latest version of iTunes onto your computer, following the instructions detailed on the Apple website. Connect the iPhone 4 to your computer using its USB cable, and click the "Sync" button in the lower right corner of the iTunes window. This will back up your iPhone 4 prior to jailbreaking as a safety precaution should you need to restore it. Launch your iPhone 4's "Safari" web browser by tapping its icon on the home screen. Click on the link " http://www.jailbreakme.com/ " This will take you to the JailbreakMe website. Tap the blue "Free" button in the upper right corner, and then tap it again when it turns green and its text changes to "Install." This will download and install the Cydia app store on your iPhone 4, and begin the jailbreaking process. Launch Cydia by tapping its icon on the home screen once installation has completed. Tap the "Complete Upgrade" button, and Cydia will be updated to the latest version. The iPhone 4 will reboot to complete the jailbreaking procedure. Hope this helps.
Dec 23, 2012 | Cell Phones
I have iphone 3g version 4.1 i wont to unlock it
You can try to use "tinyUmbrella" to see if cydia has you ssh on file..
tinyumbrella website
once you start the software you click the button save my ssh..
once it's done processing you can click on start tss server
This tss server will allow you to bypass itunes server which restricts downgrading firmware...
Once Tss server is running you can start itunes
once itunes detects your iphone shift + click on restore
Select the iphone 3g 4.0.1 firmware (goto http://www.felixbruns.de/iPod/firmware/ to download this)
Once it restores fully at the end it will give itunes error '1015'
dont worry..
Install Libusb if you dont have it..(Click here)
after installing libusb just use this program.. ih8snow
Click on "Fix recovery mode loop"
Click on yes to "do you have libusb installed??"
Select iphone 3g from the list
your iphone will reboot..
now you can first activate it ..
then you can use safari to goto Jailbreakme.com
slide the slider at the bottom...
it will download cydia
when cydia is installed you have to add "repo666.ultrasn0w.com" as a source
Its a zero "0" in the sn0w not "o"...
Search google how to add new sources.. to cydia..
Once you are done installing the application inside the repo666.ultrasn0w.com source your phone will be finally unlocked..
Of course easier way out would be to pay someone who knows how to do this..
regards
Oct 21, 2010 | Apple iPhone 3G Black Smartphone
Unlocked iphone 2g upgraded to 3.1 not starting after cydia swirly mms2 upgrade
You can research how to SSH to the iPhone but I suspect your only solution would be to restore your iPhone using iTunes.
Connect the phone to iTunes, hold the power and home button until the phone reboots, then release the power button but keep holding the home button down. Your computer should install a new driver and the phone should be recognised in iTunes. Please note the phones screen will remain off, this is normal. Click the phone on the left pane and then click restore. This will reset the phone to it's factory settings so you can start again. Some jailbroken apps can cause the phone to not function correctly if they are incompatible with your OS version.
Hope this helps, www.PuterCare.com
Oct 27, 2009 | Apple iPhone Smartphone
IPhone 3G camera not responding
1. Backup your iPhone in iTunes and restore.
2. The 3.0.1 and 3.1.2 firmware's Blackra1n can jailbreak them.
Oct 08, 2009 | Apple iPhone Smartphone
Tried downloading mms app from cydia and phone is frozen
Apps from non-Apple places typically don't go over well. You'll need to do a back up and restore (as new) with iTunes. AT&T has released official MMS as of 09/25, please use it and be sure you have the latest 3.1 software (it will download automatically in back up and restore). Always be cautious with 3rd party app stores, half my calls every day are about sites that crashed people's iPhones.
Oct 02, 2009 | Apple iPhone 3G
Iphone wont reboot
With phone off connect to itunes and then hold home and power buttons for 6 secs. then release power still holding home until itunes sees phone. If that doesnt work with phone off hold home and plug in phone to computer and see if itunes sees phone. Then restore
Aug 08, 2009 | Apple iPhone 3G Black Smartphone
I downloaded and MMS app frim cydia, and now my phone wont start
hi,
basicly you need to do a software restore or update on your Iphone. When using Itunes 8.2 you can just select your Iphone and in the summary select either restore or update. I would recommend that you update it seeing that the software version 3 does allow mms
Iphone wont turn back on after cydia download
Open itunes. with your phone off hold home button and plug phone into computer and hold until itunes sees the phone. You can restore then. The phone will be in dfu mode. If that doesn't do it connect the phone hold home and power for 6 secs. then release the power button while holding the home until itunes sees phone. Restore and use your phone again...
Jul 26, 2009 | Apple iPhone 3G Black Smartphone
Iphone wont start after downloading new app
conect ur iphone with pc open itunes and if itunes ask u ur device will be restore and update then press ok button all will be ok. or just click the restore button. this will download necessory files for ur device and after complete all will be ok.
Jul 25, 2009 | Apple iPhone 3G
My iphone does not restart only shows the apple
You bricked your device!
Hold the Power+home buttons for 10seconds release the power button and continue to hold the home button plug into iTunes and restore it
Jul 19, 2009 | Apple iPhone 3G
Apple iPhone 3G Black  Smartphone Logo
387 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
