Question about Ducane F7011013
Ducane Firelight Campstove/Grill Regulator/Hose Assembly
I have a brand new Ducane Firelight II Campstove/Grill that is missing the regulator/hose assembly. Not knowledgeable enough to piece together generic parts. Would like to find original configuration. Please help!
Interested in your stove does it have all connections ready for use like regulator jan live in TUALATIN, OREGON email me at jksbuddy@yahoo.com
Posted on May 20, 2014
I have a a never-used Ducane Firelight Campstove I will sell for $50 . I believe I paid $189 or more for it. However, I do not know in which area you are located
Posted on Mar 29, 2010
When I try to light my brand new Q300, it won't ignite. I can hear that the tank is on and gas is being sent to the grill. However, it doesn't light. When I shut the grill off and the gas tank...
What you have is delayed ignition. It's being caused by the gas regulator. It is solvable, though.
Turn the gas tank valve OFF and disconnect the hose from the tank.
Wait 5 minutes and reconnect the hose to the tank.
Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
Once the valve is fully open, light 1 burner and turn it to HIGH. Did the burner light and does th eflame height look correct? If so, light the remaining burner the identical same way. Now, to both flame heights look correct? If so, you solved the problem. Remember to always open the tank valve Very, Very Slowly. And always light the burners with the Lid/Hood Open.
If the above did not solve the problem, you will need to replace the Hose/Regulator Assembly. Since your grill is brand new, the Hose/Regulator Assembly will be covered under Warranty. Have your Proof of Purchase handy and call Weber 1-800-446-1071. Also, if you haven't done so already, register your grill before calling http://help.weber.com/register/ even if you don't need a new Hose/Regulator Assembly.
Hope this helped you troubleshoot & solve the problem.
Jul 06, 2011 | Weber Q300 Grill
I recently changed new tank on Ducane, when I tried to ignite it wont, and also I see air flow at orifice at the regulator. I feel it when I tried to put finger on the orifice. please help.
Simple solution to get you grilling again.
1. Turn the tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the valve is fully open, light the burner farthest from the tank first & turn it to HIGH.
Did the burner light and the fa,e height look correct? If so, light the remaining burner exactly
the same way. Now, do all the flame heights look correct? If so, you solved the problem.
Always remember to turn the tank valve ON Very, Very Slowly.
If the above didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly, as the regulator is locked up. You can pick one up from any home center or hardware store that sell grills and accessories for about $30.00. Take your old one with you for comparison purposes.
I hope this helped you troubleshoot and solve the problem, Please let me know and Happy Grilling!!
Jul 03, 2011 | Ducane 30400040 Stainless Steel Grill
I have the Ducane Model # 30557501. I have a low flame and the temp will not go above 250 degrees. I've tried resetting the regulator numerous times to no avail. Can I buy a universal regulator or is...
A universal Hose/Regulator Assembly will work just as well as one from Ducane. Actually, they're one in the same. Buying just the regulator is not practical, as you can not disconnect the hose from the regulator without damaging it. You can pickup a Hose/Regulator Assembly from any home center or hardware store that sells grills and accessories for about $30.00. Take your old one with you for comparison purposes.
Hope this helped you and Happy Grilling!!
Jun 26, 2011 | Ducane Meridian 30557501 Propane Grill
When i push igniter it clicks but burners won't come on and i do not even smell gas , i burped it and turned gas tank upside down once, still won't work, grill is only 5 yrs old.
It sound s like the grill's regulator is locked up from "burping" the tank. Hopefully it's not a permanent lockup. To hopefully solve the problem, follow the steps below:
2. Turn the burner(s) ON for 1 Minute, Then turn them OFF.
3. After 5 minutes reconnect the hose to the tank and open the valve VERY, VERY, SLOWLY (Slow
motion, slow).
4. Once the tank valve is fully open light one burner and turn it to HIGH. Did the burner light and
does the flame height look correct? Id so, light the remaining burner the way. Did it light and the
flame height look correct? If so, you solved the problem (with a little help).
If the above didn't solve the problem, the Hose/regulator Assembly needs to be replaced. What happened was this, when you turned the tank upside to "burp" the tank. The OPD Valve shot a hot load of gas to the regulator, when you opened it, as you normally would and permanently locked up the grill's regulator. That "burping" trick used to work with the old style tanks. Won't work with the new ones. You can get a new hose/regulator assembly at any home center or hardware store, that sells grills and accessories. They run about $30.00. Take your old one with you for comparison purposes. Once you install the new one and connect it to the tank. Open the Valve Very, Very Slowly, until it is fully open. Or you may have the same problem again.
Hope this helped to solve the problem. Happy Grilling!!
Jun 19, 2011 | Ducane 30400040 Stainless Steel Grill
The knob on the gas regulator cracked off and we are not able to get it off. Is there a special tool to get the regulator off, if not how do you replace the whole regulator and hose combination. There is...
Short of carefully using a pipe wrench, there's not much else you can do. Make sure the tank valve is fully OFF, before attempting removal. Once it's disconnected, you will need to purchase a new Hose/Regulator Assembly. They are not expensive and can be purchased at any home center or hardware store that sells gas grills and accessories. Take the old one with you for comparison purposes.
May 24, 2011 | Ducane Meridian 30557501 Propane Grill
Lost hose assembly (parts 17,18,19) of my Firelight II propane BBQ Ducane 7011013 WH-008583
You can purchase the parts you need from the Ducane Parts Center 877.731.8081. Make sure you have your Model Number handy when you call. If they can't help you go to the following link
http://grillpartssearch.com/mm/merchant.mvc?Screen=CTGY&Store_Code=Gas_Grill_Parts&Category_Code=Plumbing
Good luck & Happy Grilling!!
May 18, 2011 | Ducane F7011013
Replace Regulator and hose
I have a similar problem. I just spoke with a Rep from Charbroil and this model grille does not support replacement of just the hose..You need to replace the entire Valve Assembly. You can get a new Grille at Lowes for 10 dollars more than the replacement cost of the Valve....
Jul 17, 2010 | Char-Broil Quickset Traditional 463761006...
Ducane F7011013 FireLight II grill I am looking for a replacement burner. The one I have has rusted out. Any suggestions on where I can get one? Is there another burner that will fit in this grill? ...
I have a brand new Ducane Firelight II Camp Stove/Grill in need of a regulator/hose assembly. Would you be interested is selling me the parts from your stove? kpirish810@yahoo.com
Apr 25, 2009 | Ducane F7011013
Ducane F7011013 Logo
872 people viewed this question
Top Ducane Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Are you a Ducane Grilling Expert? Answer questions, earn points and help others
