Question about Bissell 1400 Little Green Pro Canister Steam Vacuum
Can't clean little green collection tank
I also have the same problem. The tank is dirty and soaking doesn't get the stuff off. It also now has a odor when I use it because of this problem. They made the design so crappy you can't even fit a baby bottle brush through the hole to scrub the walls of it.
  • 11 Answers
There's really nothing you can do to clean it once the stuff has dried up inside. After using the machine, clean it every time! I put hot water in a sink and **** it up into the collection tank, repeat this three or four times. Every now and again, remove the rubber anti-backflow piece and clean it out, too.
That's about all you can do. The only other thing you can do is to buy a replacement tank, they're not expensive.
Posted on Sep 19, 2009
  • 430 Answers
You could try a solution of hot water and baking soda. Works very well for coffee residue on a carafe. Dilute and filter the soda before pouring solution into the tank . then hold the tank and swirl.
Posted on Sep 06, 2009
How do I check my hoover floormate deluxe spinscrub's filter and motor? Thanks in advance!!
The filter is at the top of the recovery tank (dirty water tank), should be replaced when dirty or odors occur. as to your motor, there is no way for an end user to remove any cover and check it. If you are experiencing noise, have it checked by an authorized service center.
Oct 20, 2014 | Hoover Vacuums
My hoover steam vac has developed a musty smell. Any ideas to remove this odor?
i often use vinegar and water to clean my steam cleaners. I use a 3:1 ratio of 3parts water to 1part vinegar. using 8oz's as a part. hope this helps good luck. whoops btw use mixture to run through machine and soak dirty water tank in.
Mar 06, 2013 | Vacuums
Have bissell little green model 1400. Having trouble cleaning the holding tank (dirty water) tank. The tank comes out but the stuff doesn't rinse out - its gross. I'd like to take the holding...
Do not take it apart.If you do,it is then broken.Put about1/ cup of powdered dish washer detergent,in the bowl and fill with hot water.Let that soak for a few hours.And as the shampoo folks say,rinse and repeat,if needed.This also will clean tubs,toilets,and all ceramic tile very well.
May 13, 2011 | Bissell Vacuums
Odors
Try cleaning the main motor filter or replacing it.
Jul 15, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
My machine wont pick up the dirty water. If I take the cover off the recovery tank there is a lot of suction but it wont **** up the water. my carpet is soaked. What can I do
at power head clean out area before power head also look for small hose and clean out and look at rollers,i hope this works if you have directions still they should be able to help you out some more.thanks
Nov 29, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
The hoover steam vac 5 brush agitator dispenses water and soap but does not show any return water to dirty water reservoir. The carpet seems damp but not soaked, still a bit troubling no waste water...what...
You do not have the needed vacuum on the dirty water intake. Possible causes are:
1. No adapter sleeve in the back of the dirty water tank (the one that you remove to put the fabric hose adapter in)
2. The dirty water top is not sealed (cracked, not on correctly)
3. The intake shoot at the front of the unit is clogged with dirt/hair.
REMEMBER: This is NOT a vacuum cleaner - it is not designed to remove hair and dust.... ONLY wet dirt. If you fail to vacuum floors just before steam cleaning, the unit will clog up in minutes!!
Nov 24, 2009 | Hoover SteamVac F5914-900 SpinScrub...
My bissell ready dry doesn't clean my carpet.
my bissel ready dry is not sucking the water up
Mar 30, 2009 | Vacuums
Foul odor when I begin vacuming with My Dyson
Sounds like you have sucked up something wet and it has soaked into the liner,try vacuuming up a box of baking soda, then let it soak up for a day or two.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 21, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dirty Tank Smells
You might try vineagar, if that doesn't work, put in some comet or some other scouring power, then fill w/hot water and let soak for awhile.
Feb 11, 2008 | Bissell 1425 Little Green ProHeat Handheld...
Bissell 1400 Little Green Pro Canister Steam Vacuum Logo
289 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
