Question about Brother CS-6000
Adjust stitch length on my brother cs 6000i
How do I increase stitch length on my brother cs 6000i sewing machine?
bargainbox
  • 1388 Answers
SOURCE: stitching looping
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....the question you pose could have 2 meanings....this reply is for looping thread.
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
cc3f045.jpg...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all back properly.
FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes. ie a different colour top and bottom just for the test.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is, and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine case....no case ? then make some sort of cover ! Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you need any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Feb 23, 2008
SOURCE: I get an E6 message while trying to sew on my Brother cs-6000
Here is the online manual for your machine. http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_CS_6000_ES_2000_EN_185.PDF
Posted on Mar 30, 2009
suiz_q
SOURCE: sewing machine Brother Cs-6000i don't work
let me know too, mine won't turn on, worked just fine yesterday, Suz
Posted on Jul 06, 2009
  • 1116 Answers
SOURCE: Brother CS-6000i - the bobbin thread is not coming
Check list:
1 - Flat side of the needle is facing the back of the machine.
2 - Threaded machine with the presser foot up - always.
3 - Bobbin thread is feeding from the spool in the correct direction and through the proper guides.
Lower and raise the threaded needle, holding onto the end of the thread.
If this does not pull the bobbin thread up, the timing may need adjusting.
There is a graphic for doing this as sewusa.com or take it into the dealer for service.
Posted on Mar 10, 2010
Jimsta01
  • 405 Answers
SOURCE: How to thread a Brother cs-100 sewing machine
Please follow the link below, for the manual
http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000207/cs100ex660qg01enfres.pdf
Posted on Mar 30, 2010
My straight stitch is not perfectly straight, what can I do?
1. Put a piece of paper on the sewing machine w/o thread. Sew for three inches.
2. Notice the needle holes are straight with the feed dogs. The pressure foot is not in line with the holes.
3. With the pressure foot down loosen the pressure foot pressure to it's lowest amount.
4. There is a screw on the arm that needs to be loosened. Afterwards, adjust the arm until the foot is parallel with the feed dogs. Tighten screw.
5. Try sewing again on the piece of paper to check for accuracy on being straight.
6. One other check is to insure the feed dogs have even wear.
Mar 04, 2015 | Brother CS-6000i CS6000i 60-Stitch...
A lot of squeezing, tight sounding noise, coming from inside. Can it be oiled??
yes, recommend a drop if 3-in-1 oil on all moving joints, connections, gears, and wipe off any excess.
Oct 19, 2014 | Brother CS-6000i CS6000i 60-Stitch...
How to trouble shoot without a manual?
you can download a free manual at //www.generalmanual.com/Home-Sewing-Embroidery-Machines/Brother-CS-6000i-Sewing-Machine.htm
F4 might mean that the bobbin on the top is in the position for rewind, slide bobbin to the right for the error code to go away. Hope this helps, Sandy
May 03, 2014 | Brother CS-6000i CS6000i 60-Stitch...
How to troubleshoot without a manual
Yes, Brother has a free download, Go to this site:http://www.generalmanual.com/Home-Sewing-Embroidery-Machines/Brother-CS-6000i-Sewing-Machine.htm and you should have what you need. You also might have the bobbin pushed to the right, in the wind position. Is so, push bobbin to the left and all should be fine.
I have a brother 6000i. How do I utilize the extra spool pin?? Where does it go ?
bAttach the extra spool pin.
Put the extra spool pin in the hole on the top of
the machine. Put the second spool of thread
onto the extra spool pin.
See page 25 in owners manual.
Feb 25, 2014 | Brother CS-6000i CS6000i 60-Stitch...
I keep getting error E6 on Brothers CS 6000i- I cleaned the thread several times and when I try to restart sewing it happens again. I've removed the bobbin and re-threaded and it keep jammin and beeping....
The motor locked up because the thread is tangled.
Solution:
Remove the tangled thread before continuing the operation.
Clean the bobbin case to remove the tangled thread.
After cleaning the bobbin case, insert the bobbin case properly.
If the needle is bent or broken, replace the needle.
Then, thread the upper thread properly, and continue the operation.
Dec 21, 2013 | Brother CS-6000i CS6000i 60-Stitch...
I don't know how to adjust the tension on my brother cs-6000i.
It is the wheel on top of the machine near the thread guide.
I believe you will find more information on page 29 of the manual.
Mar 11, 2010 | Brother CS6000i Computerized Sewing...
Unable to adjust tension,
Sounds like the bobbin thread is not inside the tension on the bobbin case. This normally happens when the bobbin is upside down. Insert the bobbin and pull on the thread.The bobbin should turn counter clockwise.
sewman7
Jul 15, 2008 | Sewing Machines
Brother CS-6000 Logo
99 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
