Home | Philips | 55PP9401 55 in. Rear Projection Television | Double lettering on red...
Philips 55PP9401 55 in. Rear Projection Television
Problem for Philips 55PP9401 55 in. Rear Projection Television
Double lettering on red when in 1080i good picture in 480p
By gbrian76 on Sep 06, 2009
Phillips 55PP9352 rear projection tv. Picture is great when cable receiver is in 480p and when its set to 1080i the picture gets blury with double lettering. The cable man pulled up a screen with red and green + that didn't line up and another screen with blue + that looked fine. Called tv repair shops and one told me I needed a convergence and it would cost about $300. Is this something I can fix myself without causing more damage or is worth the $300 to get it fixed?
Solution #1
posted on Sep 06, 2009
Not Rated)
Ecollier2012
Rank: Guru  Philips Expert
Rating: 93%, 540 votes
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Was this helpful?
Yes
No
Popular Solutions for Philips 55PP9401 55 in. Rear
Questions and Unsolved Problems for Philips 55PP9401 55 in. Rear
Do you recommend Philips 55PP9401 55 in. Rear Projection Television?
Answer
Answer
it took a while to power on now there is no picture or sound
Answer
Hi, I've a Philips Projection TV PTV392, model 52LP50. The problem is that blue ace is down than... (More)
Answer
i have a 55pp9352 and the red went out of wack and its to far out to bring it back with the remot... (More)
Answer
my philips 60PP9202 converge multipoint lines will NOT line up when i try to adjust them!! please... (More)
Answer
my tv turns on then 9 clicks later it turns off,then the process repeats
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Philips 55PP9401 55 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
