Question about Xerox 212 Laser Printer
Copier is a 214 and shows U4 code
Copier displays a U4 code....please help !!!
    Habit-Forming:
  • 96 Answers
Turn on power while holding down "0", press "stop/clear" and wait 30 seconds for optics to finish initializing, then enter "401" then "print", shut off machine, wait 10 seconds and turn back on. code should now be cleared.
Posted on Oct 10, 2017
My Copise Xerox work center pro 423 are showing on display this error (U4-2) how i can clear this error please please tell me any body if knows
my copise xerox work center pro 423 are showing on display this error (u4-6 @ reboot) how i can clear this error please tell me
Mar 18, 2011 | Xerox WorkCentre Pro 423 Copier
Xerox wc pro 423 u2-3 problem
my Copise Xerox work center pro 423 are showing on display this error (U4-2) how i can clear this error please please tell me any body if knows
Nov 16, 2010 | Xerox WorkCentre Pro 423 Copier
Copier is a 214 and shows U6 code
A U-6 means the memory on the main board failed.
If the machine is old, the battery on the board is old and not holding the values in the machine.
Replace the main board will correct the problem.
Since it is in the middle deep in the machine you might need to have Xerox repair it for you if they still provide service to this model.
Good luck.
Sep 06, 2009 | Xerox 212 Laser Printer
U4 error code - Xerox 5328 copier
U4-2 Low fuser temp problem U4-3 High fuser temp problem U4-4 High fuser temp problem U4-6 High fuser temp problem
replace thermistor in fuser unit
Oct 03, 2008 | Office Equipment & Supplies
Xerox 5334 fault code U4-1
Reset the fault code first as follow:
Enter in diagnostic mode
Enter 20-3 and press 0 then press start again .
Hope it will solve if not done check the heater lamp continuty if found fault replace same.
Sep 06, 2008 | Office Equipment & Supplies
My machine shows a U4 code
U4 code refers to a fuser heat failure, you'll probable find the fuser roll is stone cold .Possible cause is open circuit heater or overheat thermostat popped.Either way you will need to pull out the fuser unit and check continuity of the components
May 29, 2008 | Xerox WorkCentre Pro 423 Copier
My xeros 214 copier has gone wrong and the no U4 is coming up, i do not have a manuel thanks terry
A U4 is a fuser overtemperature.
You can hold down the "0" while powering the machine on. That will enter the machine into diagnnostics.
Next enter code 401, and press start, See of that clears the problem.
If it does. Remove the fuser and clean the buildup off the thermistor.
If it doesnt you will most likely have to replace the fuser.
May 15, 2008 | Xerox Office Equipment & Supplies
Xerox Copier 214
If it does. Remove the fiser and clean the buildup off the thermistor.
Jan 29, 2008 | Xerox WorkCentre 214 Laser Printer
Xerox Copier Machine - Error U4
The fuser is not warming up.
On that machine under the web there is a thermal fuse on a white plastic mount, it has one screw through it.
It is most likely blown. Possibly caused by a jammed paper in the fuser.
That fusable link needs to be replaced.
Jan 02, 2008 | Panasonic DP-150A Copier
Xerox 212 Laser Printer Logo
126 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
