Question about Brother MFC-665CW All-In-One InkJet Printer
I have brother m#665cw with "unable to print 50" quote problem
Mix-it-up
  • 832 Answers
SOURCE: Brother MFC-665CW
same issue:
http://www.fixya.com/support/t294185-brother_mfc_240c_change_unable_50
Posted on Feb 21, 2008
yooperbud
  • 8637 Answers
SOURCE: I have a brother mfc
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 25, 2009
eagle338
  • 4889 Answers
SOURCE: MFC-665CW "unable to print" 50 error
Did you have a paper jam before this happened? If yes then the paper must have pushed the encoder strip out of alignment. You will need to turn off the printer and then push it back into slot to fix it. Let me know if you need more help. Sai.
Posted on Jun 11, 2009
  • 138 Answers
SOURCE: Im getting unable to print
The paper jam you had probably lifted the long, thin, plastic encoder strip out of its slot. It is making the printer think paper is still jammed. Try gently pushing the strip back into the slot. You might have to use a screwdriver or other thin instrument to get to the strip.
Be sure printer is off when you do this.
Posted on Sep 19, 2011
matt800
  • 241 Answers
SOURCE: MFC-665cw unable to print 50
hen you open the printer so that you can see the print head, move the print head with your hands, pull it to the middle. The space immediately to the front of the printer is blocked by the plastic shield. you can curl your fingers down under this shield. you will feel the encoder strip, which is about 8 mm wide, and is a plastic ribbon, or strip. It runs from left side to right side across the printer, in a vertical orientation. This is the encoder strip. Past this you can feel a longer rubber belt, which is about 3 mm wide. This is not the encoder strip, it is a belt and you don't need to be concerned with this.
Place your fingers on the encoder strip on either side of the print head, and flex it, bending it up and slightly back and then release it. Try this several times. Do this with power on. Once the encoder strip is back into it's slot the printer will start a cleaning cycle and start working.
Solution found here originally.
Posted on Oct 16, 2012
How can we fix when a mesage says unable to print 50?
paper jam or some sensor problem, clear the paper jam, or clean the sensor under the pump.
Jul 30, 2014 | Brother MFC-665CW All-In-One InkJet...
I haved an error message on my Brother MFC-665CW--unable to print 51
in my printer brother mfc-7340 when i coping with machine after some time display will show print unable with error code 72 what i will do? plse tell me;
Apr 07, 2013 | Brother Multi-Function Center MFC-665CW...
Im getting unable to print 50 error on my brother mfc 665cw
Sep 18, 2011 | Brother MFC-665CW All-In-One InkJet...
Unable to print 30 and 50...what do i do?
what do i do...unable to print 30 and where is the encoder at?
Sep 03, 2009 | Brother Multi-Function Center MFC-665CW...
Unable to print 30 or 50
the encoder strip is probably out of its socket. its a long mylar strip that goes from one side to the other, and goes underneath the printhead.
Jun 25, 2009 | Brother Multi-Function Center MFC-665CW...
Jun 11, 2009 | Brother MultiFunction Center MFC-440CN...
I have a brother mfc 665cw printer, had a printer jam, cleared the jam and now recieve unable to print 50 error, unable to copy or print. Have found some information about the encoder strip but I have no...
Jan 05, 2009 | Brother Multi-Function Center MFC-665CW...
Cleared printer jam, message Unable to print 30
...and 50? Is it toggling between those two error codes?
Anyway, see here what to do:
http://www.fixya.com/support/t211210-brother_mfc845cw
Mar 11, 2008 | Brother Multi-Function Center MFC-240C...
Brother MFC-665CW All-In-One InkJet Printer Logo
146 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
