Question about Troy Bilt 5.5hp Self Propelled Mower
Mower want start
Changed my battery cleaned spark plug what am i looking for when i check to see if its getting gas
    President:
  • 1,776 Answers
First, pull the spark plug and see if it is wet/damp with gasoline. That's one way to tell if it is getting gas. Try starting the engine with starting fluid. If it will run with starting fluid, but not on it's own, it is a pretty good bet that there is a fuel delivery or ignition problem. Sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 06, 2009
How can I tell if my starter is bad on my cub cadet rtz mower
Check for spark
Have to get the test plug for small engines
Is the battery years old & partially dead?
Is the oil clean & full
Won't turn over or won't start?
Clean the flywheel & ignition coil or whatever
system it has for spark
Check for intake gasket leaks.
Did the meter always go down to 9.8 when it did start?
Your best to work on things & learn-- when they work correctly,
not wait for years then be lost
May 08, 2014 | Cub Cadet Garden
Hi I did a tune up ,changed and checked every thing I done ..too I changed the oil ,oil filter ,gas filter air filter ,got a new battery changed the plugs there new too...even a new belt new key ...but...
Spark and gas??? Must have both. Pull spark plug wire and check for spark. If you have spark, check gap on spark plug. Check the bowl on carburetor. loosen bowl screw to see if gas is coming out. If you have gas coming out, carb needs to be taken off and cleaned or rebuilt.
Oct 11, 2013 | Cub Cadet Street Sign- tractor lawn riding...
Start and ran the mower for 10 min Shut it down and now can't get it running for more than 10 sec. Changed the gas drain the old gas Changed the spark plug, cleaned the filter as stated. still can
Tecumseh engine right? Pull the float bowl off the carb. I suspect some water contamination. while it is off clean the jet holes in the nut. They may have varnisized gas in them. contact me with any more questions.
Sep 13, 2012 | Yard Machines Garden
Lawn Mower will not stay running then will not restart
I think we all understand the frustation penaone.
I noticed u didn't clean the fuel tank, water, dirt, and rust in it can give u problems. But u need to clean the lines and carb. again also. One of the kids filled my mower gas tank with driveway gravel once, and after I cleaned things out, the mower never run so good. Also your spark may be grounding out somewhere before it gets to the spark plug. Check for a bad spot in the wires from the magneto. Some of that may be behind the flywheel though.
ballping
Jul 28, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Lawn mower won't start /troy built 100706
First check to see that you are getting a spark. if you are getting spark (if same plug when you bought it change spark plug) make sure it is correct plug for that mower, make sure you have good gas. If still not starting and the machine probably was sitting for a while, clean the carb and then it should run fine.
Sep 01, 2009 | Garden
My toro 6.5 self propelled mulching mower with guaranteed one pull start will not start. It will start for 5 seconds and then shut off. I have changed the oil, filter, and put in fresh gas. Nothing has...
IF THERE IS A PRIMER BULB ON THE CARB CHECK AND SEE IF IT IS HOLDING GAS IF NOT THE CHECK VALVE UNDER THE PRIMER IS BAD AND SUCKING AIR
Aug 12, 2009 | Garden
Lawnmower wont start
Possible Causes Corrective actions
Unit will not start Control handle is not engaged Engage control handle spacer.gif spacer.gif
Spark plug wire is disconnected Connect spark plug wire spacer.gif spacer.gif
Fuel tank empty or stale fuel Replace with clean, fresh gas spacer.gif spacer.gif
Air filter filled with dirt or debris Replace or clean air filter
May 23, 2009 | Mtd 22" Yard Machine Push Mower
Mower will not start
Hi
Take the spark plug out and pour a little bit of oil in the cylinder and crank it over without the spark plug in. Make sure ground wire is clean on both ends.
Apr 13, 2009 | Garden
Troy Bilt 5.5hp Self Propelled Mower Logo
88 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
