Question about Zebra Printer 140-751-00000
The Zebra 2443 printer is feeding out 13 to 14 blank labels (2.25 x 1.38) before printing a message "No Gap Detected" and then two labels later printing the label I want but not centered on label.
  • 32 Answers
It sounds like the printer is not calibrated. This procedure is in the users guide. Make sure both labels and ribbon are loaded correctly and then perform this procedure. If you do not have the manual or still have issues, email me at hilster1968@gmail.com for the procedure.
Posted on Oct 27, 2009
Zebra s600 prints on label and feeds 3 blanks
it must be wrong label configuration or problem with gap sensor.
You can follow this step by step zebra designer ;
Zebra Designer Kurulumu ve Kullanm Teknik Barkod Etiket
Jul 02, 2014 | Zebra Stripe S600 Thermal Label Printer
My Zebra ZDesigner LP2844 feeds a blank label after printing a label. How do I make it stop doing that?
Define your label size correctly. Measure your LABEL exactly, do not include the backing paper or the gap. Calibrate the printer. HOW?
Power off printer. Press and hold the green feed button down and power printer on. Count one, two and release green button. The printer will calibrate and move labels and then print some stuff on the label. Wait until it has comletely stopped. wait another few seconds and the press the feed key once. The printer will print "out of dump". You should now be ready to print again.
Aug 31, 2013 | Zebra LP 2844 Thermal Printer
No gap detected
This could be caused by a couple of issues:
  • Dirty sensor (use compressed air and blow out printer)
  • Wrong media (using labels with black bars obscuring the gap and making it non-readable by sensor)
  • Wrong label format for size of labels used (make sure label size matches the template size)
Zebra printer no gap detected
Dec 12, 2012 | Zebra Eltron TLP 2742 Thermal Label...
Gaps in barcode with Zebra S4M
The gaps run in the direction of the label feed? You have a bad printhead. Bad dots on the printhead prevent it from printing your format in the areas that you see the blank lines.
There is no easy fix other than replacing the printhead. You can prevent (or actually prolong the time between failures) in the future by periodically cleaning your printhead. It's recommended that you clean the printhead after every roll of labels. The printhead is underneath the hinged assembly. Over time, ribbon or adhesive from the labels builds up and causes dots to go bad - creating the blank lines you see. Clean your new printhead with rubbing alcohol.
May 15, 2010 | Zebra S4M Thermal Label Printer
Hi I have a Zebra ql220 printer that prints about 4 or five blank labels in between barcodes. Is there a way to manually adjust this via the printer. I got a message on one printer about bar gap sense not...
Press and hold feed button for 2 -3 seconds and switch on printer.Printer will calibra and print test page .if problem is not solved Go to printer menu and select ribbon and media calibration.it will calibra te printer and problem will be solved
Aug 03, 2009 | Zebra Printer 140-751-00000
I have a zebra 110XiIII Plus 300 DPI printer that is randomly printing blank reciepts. It's connected to the computer via a USB cable. There is no rhyme or reason to the blank printing, just does it...
This is usually caused by the sensors being dirty or the printer needing calibrated. Blow off the media and ribbon sensors and also do a manual calibration. If it is still skipping after this then it is software related.
Jun 11, 2009 | Zebra 110Xi III Plus Thermal Printer
An extra, blank label prints from a Zebra 2746e.
Check media settings in the printer driver. Check version of printer driver. Zebra printersuse an internal printer driver with their Zebra Designer software (Zdesigner driver) or a ZUD (Zebra Universal Driver) for other windows applications. These drivers can be downloaded directly from the zebra website.
Alternatively you can download the seagull scientific driver and use that instead. (used with bartender program)
Label skipping occurs if the media dimensions are not specified correctly. The important ones are label height, and media setting for type of media.
Perform a media calibration before you go changing settings. Power on printer, Hold top and bottom buttons in on control panel for 5 seconds, release bottom button only then when printer starts feeding labels release top button. When printer finishes press feed button.
Mar 16, 2009 | Zebra 2746e Thermal Printer
Zebra LP2443 thermal label printer wont print
Hi Buck,
What type of labels are you using?
Cheers
Bob
Jan 12, 2009 | Zebra LP 2443 Thermal Label Printer
Zebra TLP 2844 Desktop Printer
make sure you have selected the correct media in the printer driver. The tracking mode has 3 options, (1) Web Sensing (Cut Labels), (2) Mark Sensing (Black marks on back of liner) and (3) Continuous . In your case select continuous. It sounds like the printer is in the wrong media mode and is feeding labels looking for a mark or gap and when it doesn't find one it flags a media error.
Aug 15, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra LP 2844 prints blanks
If the printer is printing nothing but blanks, try another roll of labels.
If the printer is printing blanks in between labels, it probably needs to be gap sensed. You can do this by:
1. turn the printer off.
2. hold the feed button down and then power the printer back on while still holding the feed button down.
3. release the feed button when the light flashes.
4. the printer will then regap itself
5. when the regapping is done, press the feed button once. It will print on the label that it is 'out of dump'
6. the printer should then be ready to go.
May 03, 2008 | Zebra LP 2844 Thermal Printer
Zebra Printer 140-751-00000 Logo
357 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
