Question about Vacuums
The rollerbrush attachment will not engage when connected to the power source
  • mari_potter Sep 07, 2009
    It is the Filter Queen Magestic
  • Chemist1961 May 11, 2010
    Please provide make and model
  • 430 Answers
Check the connection where the hose meets the vac itself. Then post back with brand and model
Posted on Sep 06, 2009
My vacum cleaner won't pick when attached to the parts or bottom
Hi, it's Allie from Crucial Vacuum.
It sounds like your unit may have a blockage. Checking your hose for any blockages is very easy. Remove the hose from both ends and check for blockages, any leftover debris or clog will not allow the unit to have suction.
You can purchase direct your replacement belts, filters and rollerbrush from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/dirt-devil-f1-kit.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Sep 04, 2014 | Dirt Devil Breeze Bagless Cyclonic Upright...
The rollerbrush not turning
The brush roller may be clogged with hair inside the end caps. If you remove the brush roller and it does not rotate freely, you have found the source of the problem. The end caps may have to be removed to get access to the clogs
Mar 26, 2013 | Dyson Ball DC24 Bagless Upright Vacuum
Hi, my kirby makes a very loud and rattly noise when im vacuming, and sometimes the roller brush stops working, please help thank you
replace fan,belt and either clean ends of rollerbrush of string, hair, floss, etc or buy a new rollerbrush
Dec 08, 2010 | Kirby G5 Bagged Upright Vacuum
Surfacemax 300 yellow eureka vac. is there a belt? if so , what is the belt number and how do you change the belt? most vaccs have this info on the product a is not ablet to locate this info. tnanks
On the top yellow part above the rollerbrush, there are two screws. Take them out. Insert your fingernail into the part where the yellow meets the rubber and lift. The yellow should pop off. Follow the directions printed on the label inside, directly above the rollerbrush to change the belt.
Your vacuum SHOULD have come with a replacement belt as well as an instruction guide. The instructions for replacing the belt are there. If you don't have this, well, that's why I typed this out. :) You can purchase a belt on eureka.com by looking under customer service, and putting in your model number. This is located on the label on the back of the vacuum, under where the cord goes through that loop thing.
Oct 24, 2010 | Eureka 6833D SurfaceMax Canister Vacuum...
How do i replace the belt on my vacuum
There are two black screws on the back of the hood top that need to be taken out and then the top hood will come off forward. Then you can see the belt and rollerbrush. Slide to rollerbrush out and put on a new belt to the motor pulley and then put belt onto the roller and insert it back into the nozzle housing
Nov 26, 2009 | Fantom Vacums Cyclone XT Upright Vacuum
No power getting through
Hi
The motor spindle should NOT rotate when there is nothing attached to the front. Its very dangerous. There are two square switches on the front of the machine which engage depending on wether its the main head or hose thats attached. Looks like on of them is sticking
Rob
Mar 07, 2009 | Vacuums
Possible broken belt - where do I find access to the belt. The beater bar does not rotate when i release the handle. I like this machine, but It is only 2 years old, the warranty has expired. And i must...
as you do not say which type of vac ? but assume definately upright hoover/dyson or similar ? the actual belt is not difficult to renew on either model/s at this stage can only suggest you turn vac over to reveal the cover that houses the rollerbrush the drivebelt will be located on one end of the rollerbrush but concealed by cover now? look at this cver to see how it is secured ie screws or even plastic twist 45 degree turn lock pins with slotted heads?? remove cover and you will be able to see how belt renewal is done the rollerbrush can be lifted out of its slot in position for cleaning and facilitate belt renewal hope this assists you to diy best wishes
Oct 19, 2008 | Vacuums
Electrical
PROBLEM: THE KIRBY WILL NOT TURN ON AT ALL
POSSIBLE CAUSES:
Please note......The Kirby has TWO safety switches that need to be engaged before it will operate. One is on the fan case in the front. It is activated by having an attachment attached to the front. (hose, power nozzle, etc.) The other switch is on the side of the Kirby where the cloth bag attaches and is engaged by the little tab that sticks out from the side of the hard plastic cloth bag "boot". The bag boot MUST be completely engaged to activate the safety switch and allow the Kirby to power on. If you are having trouble getting the bag to properly engage, (sometimes they are STUBBORN) simply lubricate the black gasket that the boot fits onto with gasket lubricator, VASELINE, or try a tiny drop of DISHWASHING DETERGENT or HAND CREAM. It doesn't take much, so use the smallest amount possible to get the desired effect. You should hear a slight "pop" when the bag completely engages.
If neither of these things are indicated, it is probably again, either the power cord, switch or the carbon brushes.
If your Kirby is sparking there are a few causes...
PROBABLE CAUSE (MOTOR): Worn out carbon brushes, bad armature or perhaps BOTH
PROBABLE CAUSE (CORD): The cord has a short in it. Replace the power cord
PROBABLE CAUSE (POWER NOZZLE): There is something metallic stuck in the fan or power nozzle
I think you have a problem with the carbon brushes and amature because of where you describe seeing the sparks. I would suggest taking it to an authorized dealer for repair if it is the motor that is going bad.
Apr 01, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Smell/suction
The brushroll may spin when looking at it but stops when pressure of the floor is applied. The belts stretch, so they look fine but are not. The smell - if it's a rubber smell - would also be the belt. Some, or most, brushrolls can get hair in the ends that could also cause a smell and belt problem.
Dec 17, 2007 | Eureka 2971AV EZ Kleen Bagless Upright...
Using attachments...can't find my manual ; when using attachments the
hi in answer to your question regarding the belt driven roller/brush on bottom of vac ? the nswer is yes it still rotates when you are using the tools on connection to flex hose ie stair carpet or areas the vac will not enter one word of advice ! if you use the vac/tools to vac the car interior as i and others do ? then ensure that whilst vac is stood and the flex hose and tool are in use? suggest you stand the vac on a flat surface(not the tarmacdrive or any porouse surface) preferably a rubber mat? or board so the rollerbrush is not subject to damage or apt to pick up stone chips etc which will eventually damage the motor impellor hope this helps answer your question and understand the safety point i mentioned best wishes
Oct 23, 2007 | Hoover U5018-900 Bagged Upright Vacuum
Vacuums Logo
16 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
