Question about Toro Garden
IT WANT IDLE WHEN YOU TRY TO START IT SHUTS OFF
  • 89 Answers
Sounds like your govenor spring is not attached so it just goes to idle the tighter thr spring the faster the speeds
Posted on Nov 04, 2009
I have 2004 Toyota Corolla with a remote start when starting the car idle is very high then shuts down
most likely idle air control valve on throttle body remove rubber air duct that runs from air filter spray real good with carb spray wait 30 minutes for it to dry should improve condition
Feb 26, 2015 | 2004 Toyota Corolla
John deere shuts off when mowing
sounds like you have sensor gone wrong.try to check what sensor you use thru your manual
Jul 17, 2014 | John Deere 1966 110 Lawn Tractor 7 Sprayer...
1998 Honda Accord engine rumbles and stops
rumbles?, did the RPM drop below 800 RPM? that is called idle failure
and when it does, idle can go to 400 rpm and will shake hard.
and is normal for illegal idle speeds. so post that first.
post that engine stalls
and that the RPM is 400-500 just before the stall.
then post if the fast right foot can save the stall (a key test !!!!)
if easy the ISC is sticking.
if tad hard the EGR is stuck open'
if impossible to save. then more possible (many)
ever do the 60k mile tune up this decade????,. if not why not./ now.
Dec 08, 2013 | 1998 Honda Accord
My 98 jetta 2.0 will not hold idle by itself until reaching operating temp. then a good long idle. in drive it completly shuts down after about 10-15 sec driving. will start up run for a few sec and shut...
Try replacing your Engine Coolant Temp Sensor, it's cheap and easy to replace. Just remember do it when the coolant is cool to work with before you start cracking a pressurized system.
Mar 02, 2010 | 1998 Volkswagen Jetta
Car wont hold an idle and shuts off after u start it,idle drops down to 0 when i take my foot off the gas
Have your idle air control valve and throttle position sensor and mass airflow sensor checked
Jul 19, 2009 | 2000 Nissan Maxima
2003 toyota highlander. when starting it wont maintain idle.
Try to adjust the idle of the truck because there is a possibility the idle is low and if still not work put the gear in neutral and then start it and step on the gas pedals for 20 sec.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
Jun 09, 2009 | 2003 Toyota Highlander
Rought idle then boggs out and shuts off.
I would start with changing the plugs, especially if they are original. If doing yourself, make sure to use anti-seize on threads of new plugs, gap plugs to manufacturer specs, and properly torque plugs to manufacturer specs.
Also, if it has been sitting for a while, change fuel filter, oil, and top off with fresh gas.
May 18, 2009 | 2003 GMC Sierra 1500
Engine Starts, then immediatly shuts down
mass air flow sensor, or idle control valve.
Apr 28, 2009 | 1989 Dodge Raider
Won`t idle
change the idle air control valve. this controls idle.
Jan 21, 2009 | 1998 Ford Explorer
Garden Logo
111 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
