Question about Pentair 1.0 Hp Whisperflo Pump
Ghart106 asked: "WhisperFlo 1 HP - 110V - how do you wire it?"
  • Pj Kiley
    Pj Kiley May 11, 2010
    there is a diagram on the side of the motor. make sure 110 you have coming from the timer.If not and you have 220 you can switch to 220 inside the motor
  • 25 Answers
There is a wire diagram on the inside or outside of the motor housing. There is a simple wiring switch that you can do to change the motor from 110 to 220 or vice-versa. Everything you need to know is on the motor.
www.cpo2go.com
Posted on Dec 03, 2010
110 volt
see side of motor for schematic take off back either turn knob to 110 volts or you have to switch the brown wire to a different lug and the white wire to lug #2 then the black or colored wire goes to #1 and white goes to #2 green to ground
Jul 25, 2013 | Pentair Whisperflo 3/4 Hp 115/230v
Wiring 110v on wf-28
see side of motor for diagram you have to move wires or turn a switch to 120 volt then wire double check before turning on
Mar 15, 2012 | Pentair Whisperflo 2 Hp Ur Pool Pump Wf28...
I T HINK MESSED UP I ORDERED A 115V PENTAIR WHISPERFLO PUMP, BY MISTAKE, HAVE ONLY A 110V AND 220V IN THE BASEMENT. ANYTHING TO BE DONE FROM THE BOX OR ?
You are fine with your 110VAC. Manufactures generally express the operating voltage of appliances with the median between what household voltages are usually expressed in I.E. 110/220 to 120/240
The only time this could be a problem is if you lived in another country that uses 50Hz Mains instead of 60Hz. I assume you live in the US so you will be fine.
Jun 11, 2011 | Pentair 3hp Whisperflo Pool Pump In -...
Pump switching off for about 10 -20 seconds, then back on. Hapens about every hour
the little house on top of the motor has a capacitor in it 90% of the time thats whats wrong with this motor it's eather a 30 or a 35 mf .
pull this off the motor and search your area for pool pump motor repair, free testing ,use your zip code in the search, ask if they can test a capasitor for you.. wait to take capacitor off till the motor cools off
about a $20.00 fix
hey if'n i was of help vote..thanks ..jay
Aug 08, 2010 | Pentair Whisperflo 1 12 Hp Pool Pump Wf26...
Wirng connecions for 110v pentair pool motor???
There shopuld be a diagram on the nameplate of the motor, or on the cover for the wiring compartment, or there is some stamped indication at the wiring lugs that tell you where to put your feed and what position the internal wires are to be in or the jumper .. for 110 volts or 220 volts.
May 29, 2010 | Pentair 3hp Whisperflo Pool Pump In -...
I have this Grizzly G1035 1 1/2 HP Shaper, and it seems like it doesn't have any torque. I have used it only a few times, and it is running in 110V mode now, but when trying to make a piece using a raised...
Check the wire size to the machine...if you are running on 110v and a 1-1/2 hp motor you should have at least 10 ga wire running to it...if not when you try to make it work and it pulls more current the small wire chokes down the voltage and you loose power..
heatman101
May 06, 2010 | HP Grizzly G1035 1 1/2 Hp Shaper
Pentair 1.0 Hp Whisperflo Pump Logo
424 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
