Question about Sony Ericsson Cyber-shot C905 Cell Phone
Sony ericssonc905 cybershot phone cant hear through the ear piece
When phone is ringing or answered i cant hear them, only if i switch the pnone to speaker. the switch is changeing it for speaker to earpiece but it appears to cut out the incoming speech regards jerry
My iphone 3g does not ring, i can hear the ring if i have on ear phones or an ear piece. the signal seems to be okay. the settings seem to be correct.
Dear Dburnett412.
If you can't hear the ringer when there is an incoming call to your iPhone 3G, you may have overlooked whether or not the ring/silent switch is set to silence the ringer. The ring/silent switch is above the volume switch. If you can see orange on this switch, it's set to vibrate. Switch it to ring and you should be all good.
If this doesn't help, you may want to consider resetting the iPhone.
Jun 30, 2011 | Cell Phones
Bold 9000 only rings through the ear piece when it is connect. Does ring when disconnected to ear piece. When ear piece is not in my ear, I can not hear the phone ring.
Hi, what makes it when disconnected to ear piece. When ear piece is not in my ear, you can not hear the phone ring is because the ringer of the phone that makes you know when there is an incoming call on your cell phone or a message alert tone on your cell phone is damaged and does not work and makes sound to notify you .
The ringer is a tiny speaker inside the cell phone that allows you to hear incoming call from your cell phone You will need to replace the ringer inside the cell phone ....
When you replace with another ringer (speaker inside the cell phone),phone will be Ok again.
Would advice that you contact an expert in phone repairs for asistance,that will do you good to prevent more damaged on the phone...
Take care.....
Feb 09, 2011 | RIM BlackBerry Bold 9000 Smartphone
On my W580i when a call is made, i cant hear using the normal speakers on the top , but when the speakers are switched on i can hear louder , using head set also it is working fine... what is the cause?,
I hope you haven't dropped your phone. It could be due to moisture entering the phone. In either case, please contact Sony Ericsson service center, as the problem could be due to a damaged ear piece.
Jul 27, 2010 | Sony Ericsson w580i Cellular Phone
When I answer a call, I cannot hear my caller as they speak.
hi...
the problem is seems to be with the earpiece. the connection to the ear piece may be disconnected.so please give for service in near by sony service centre.
Jul 14, 2010 | Sony Ericsson Cyber-shot C905 Cell Phone
Cant hear no one through the ear piece
this may be because you have recently done something to ur phone i would say try resetting it or sending back to carrier to get fixed or at least have them send u a new phone
Sep 11, 2009 | Sony Ericsson Cyber-shot C905 Cell Phone
Ringer volume
well there either should be a switch on the outside of the phone or on the answering machine part, but also, if there is a + and - button on the actually phone part to turn the ear piece up, when you are not on the phone, hit the + button and you should hear the ringer, hit it until its the loudest.
Jun 05, 2009 | GE 27998GE5 Cordless Phone
People can hear me speak but I can't hear them
Sound inducers do go bad. Normal the same audio amplifier is used for both the ear piece and the speaker. Since the speak does work, it sounds like the ear piece has died.
May 28, 2009 | Lands Phones
I cannot hear the person on the other end but they can hear me
you ear piece may need to be replaced you should take the phone to a repair shop and have them replaced the ear piece or look at the old one for you.
Mar 25, 2009 | AT&T Blackberry Curve 8300 Smartphone
When someone rings me i cant hear them?
that means that you need to take the phone and have the ear piece speaker replaced on the phone.
Feb 02, 2009 | Sony Ericsson W910i Cellular Phone
Cannot hear incoming calls unless on speakerphone
take the phone to a mobile service center and have them replaced the mobiles' ear piece.
Feb 21, 2008 | Motorola Mobility L6 Cellular Phone
Sony Ericsson Cyber-shot C905 Cell Phone Logo
179 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
