Question about Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist
Removing the ceiling mount from the ceiling of a hampton ceiling
I am trying to remove the mount from the ceiling from a ceiling fan and can't get it off the ceiling. I turned the top ccw but nothing drops down. It stays in place. Any tips for removal?
  • 34 Answers
Sometimes there is a small trim piece where the canopy meets the ceiling that "snaps" into place and rather than turning to unlock it needs to be gently pryed off. If you have a small trim piece that makes more than about 1/8 of a turn without unlocking. that is definately what you have.
Posted on Sep 10, 2009
How do I remove fan mounted close to ceiling?
There should be side mounting screws in the canopy which attach it to the mounting bracket. The screws are removed to allow the canopy and motor assembly to drop down free of the mounting bracket. A convenient hook is provided to allow wires to be disconnected.
Oct 23, 2015 | Hunter 20461 Brushed Nickel Ceiling Fan
Hampton bay ceiling fan broke. How to screw it back up
It already looks like it's "screwed up". ( LOL) BEFORE BEGINNING READ ALL OF THIS FIRST< PLEASE> First turn off the breaker that supplies power to the fan. Take down the whole unit up to the ceiling mounts. It looks like the wood is broken that the screw bracket used to mount the fan is on. If it is you will need to reinforce the wood and rescrew the fan mounting bracket on it. THe ball carrier from the bracket should now be secure and ready to mount the swing ball of the fan at the top of the fan unit motor. Next rewire the fan to the wires in the ceiling with the wire nuts you removed. Tighten the ball screw and push the cover plate up to the ceiling, fastening it in place with the screws provided to the ceiling plate...Done!
Jan 01, 2013 | Heating & Cooling
How do you remove a canopy cover from a Hampton Bay fan?
Turn off the circuit breaker supplying power to the ceiling fan. The circuit breaker is in your home electrical box and may control more than just the ceiling fan. Place a stepladder under the Hampton Bay fan.
Remove the light bulbs and light covers from the fixture, if you have a light assembly on your ceiling fan. Remove the screws securing the light assembly housing to the fan with a Phillips screwdriver. Lower the light assembly, and hold it in one hand.
Twist counterclockwise the wire nuts securing the wires for the ceiling fan and light assembly, using your free hand to separate the wires. Lower the light assembly from the fan and set it in a safe place.
Turn the screws securing the fan blades to the unit with a Phillips screwdriver. Remove the blades from the fan and set them aside. Find the screws securing the canopy to the ceiling mounting plate. Loosen the screws two complete revolutions. Turn the canopy counterclockwise and unhook it from the screws. Slide the canopy over the fan motor housing and away from the fan.
Ask a helper to hold the fan motor housing if you have a Hampton Bay fan with a down rod. Slide the canopy over the down rod until it rests on top of the motor housing. Disconnect the fan wires from the ceiling wires, twisting the plastic wire caps counterclockwise. Slide the hangar ball, at the top of the down rod, out of the mounting bracket. Slide the canopy over the top of the down rod to remove it from the fan.
Regards
Sep 28, 2011 | Dryers
Trying to remove a ceiling fan Hampton Bay model C 542 MP (CH) PBL . its flush mounted and cant get to mounting bracket.
Look for 2 to 3 screws at the top edge of the fan's ceiling cowl. Remove those and the ceiling cowl can be sled down, which will expose the the ceiling mounting bracket . They are fairly small head screws, so look carefully for them.
Hope this helped you and thanks for choosing FixYa.
Aug 14, 2011 | Heating & Cooling
How to remove a Hampton Bay Cameron Plus Blue&#65279; Ceiling Fan?
Hi.
Take the screws out of the sides of the top cover plate...drop it down, then unhook the wires and remove the screws holding the mounting plate...
heatman101
Aug 29, 2010 | Vacuums
REMOVAL FROM CEILING
In general, the steps are:
1. Turn off power at the breaker -- not just the light switch.
(There are still "hot" wires in the junction box when "Off".)
2. Take out any light bulbs.
3. Remove any light globes. Some screw in, but most are held by springs so just pull gently with a bit of force.
4. Remove fan blades. Most have a spring at the inside edge of the blade -- press down on the spring and push the blade toward the fan motor.
5. Remove the ceiling mount cover. There is usually a circular ring up next to the ceiling; just twist it off with your hands ("lefty - loosy, righty-tighty").
6. Unscrew the ceiling mount screws. Usually there is one or two in a "simple" hole, and two one "sliding" slots. Take out the "simple" screws, and loosen (but don't remove) the "sliding" screws. Be careful not to drop screws or washers into the fan motor.
7. Twist off the ceiling mount cover to expose the wiring.
8. Disconnect all wires. For safety, put a wire nut on the wires from the ceiling.
9. Tip the fan and remove it from the ceiling mount. Keep in mind that the fan is pretty heavy, and you're on a ladder!
NOTE: Be careful not to put any pressure on any of the blade holders, especially if you intend to re-use the fan. If you do, the blades will wobble.
10. If you're installing a new fan, you can probably re-use the mount. If you want to put up a simple light fixture, remove the mount by unscrewing the two long screws holding it to the junction box.
Jul 17, 2010 | Hampton Bay AC414-LRU 52'' Kemper...
Trying to remove cover that houses the ball and pipe that hangs the fan. There is no screw to hold the ceiling mount cover to the ceiling mount. I tried pushing up and twisting but no luck. Could someone...
There should be a couple of small screws at the very top on the side of the canopy...you will need to loosen these a few turns and then turn the canopy and drop it down...
This link will help you they had the same problem as you...
http://www.askmehelpdesk.com/electrical-lighting/hampton-bay-ceiling-fan-removal-25673.html
heatman101
Apr 29, 2010 | Hampton Bay 46056 Callaway II Ceiling Fan
I can't find any mounting screws or bolts on the ceiling fan motor assembly. How do I remove it from the ceiling?
Yopu first need to drop the canopy co0ver from the ceiling mount. The cover may have screws at the very top edge. It may have screws at the bottom plate. It may have a decorative plastic ring at the very top that is conceling the mounting screws. You should be able to twist the plastic ring in an unscrewing motion and pull down to remove it.
Mar 10, 2010 | Hampton Bay 24750 Huntington III Ceiling...
Cannot remove casing around ceiling. Hampton Bay
Try twisting the bezel (cover) counterclockwise to unlock it from the mounting base plate on the ceiling. The other option is to see if the bezel/cowl has fasters (screws) holding it in place either from the sides near the top edge or at the bottom nearest the narrow portion of the cover.
Sometimes the fan cowl bezel is fastened using screws at the point nearest the motor shaft.
There could also be a trim ring that needs to be gently pryed off from the edge nearest the ceiling, so you can gain access to the screws that are holding the cowl in place on the mounting plate. There are usually 2 sets of 2 screws placed 180 degees apart from each other that secure the cowl in place.
I hope you find this Very Helpful and best regards!
Aug 20, 2009 | Hampton Bay Dryers
I need to remove my hampton bay ceiling fan from the ceiling.
im trying to install light to ceiling fan but the wires are a different color and light wont come on
Jan 15, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist Logo
267 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
