Question about Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping
Ee20 whitch says your high limit is open ,Right by the limit thrers a crack in the heat excanger and i think this is my problem . because my fan seem to be working fine. could this be the problem or maybe somthing else im over looking.
  • 61 Answers
The cracked heat exchanger should be replaced at once.
While the unit is open, a compete service should be done.
Continued operation can result in further damage to your Toyo and could result in a fire.
_Helping Hands Services_
-Fairbanks, Alaska-
Posted on Oct 27, 2009
Honeywell fan limit control
Many things could bring this on. Most commonly a high limit is open tEllington the unit that the furnace has a cracked heat exchanger.
Feb 11, 2014 | Honeywell Heating & Cooling
Dryer tripped a breaker and when I turned it back on it never goes off the sensing phase and never gets hot
Dryers have what is called a "high limit", whitch keeps dryer from over heating, and protects panal. It sounds like your element has shorted out, check the "high limit" before closing up the back. This is a simple fix, but electrical knowledge is a must. Call the factory for new parts, but have model and serial numbers on hand. UNPLUG
Aug 13, 2013 | Dryers
I have a 75000 btu garage heater ,20 years old, The Fan stoped turning on and I replaced both the switches that turns the fan on by the heat exchanger and the shut off switch.It still will not turn the...
The high limit switch is shutting down too soon (too low of a temperature) or the fan on switch is not turning on at a high enough temperature...are they in backwards??? Even though the switches work they are not turning on and off at the right temps... so they may be out of calibration....
heatman101
Feb 10, 2011 | Heating & Cooling
Flame comes on, fan runs after a few minutes then unit will shut down, will sit a few minutes then sart back up, seems to be short cycling all happens within 8 minutes. \r\nmodel QVB-2505 PS. What...
there are limit sensors around fire box.you need to remove front cover.if flames are coming out of fire box there's a restriction in air flow. on older furnace could be fan belt . air cond. coil could be pluged up are all the vents open and have good air flow?you check limits by pulling one wire and check with ohm meter.there normally closed and open when too hot.most limits around fire box don't reset them selves.on some draft inducers there's a limit if it is tripping then theres a vent problem.theres also a limit on the fire box (heat exchanger) that may or may not self reset.
Jan 12, 2011 | General Heating & Cooling
The high limit thermal switch on heater burns out.
There are two thermostats, a 'limit' or 'operating' thermostat which turns the heating element on and off, and a 'high limit' or 'safety' thermostat which oversees the 'operating' thermostat by opening and removing power to the heating element when the upper limit temperature is reached. Basically, the only difference between these two are the temperature ratings. The 'high limit' is higher than the 'operating' thermostat. The thermal fuse is the last resort protection.
First and foremost, you must know that every inch of your exhaust vent pipe is clean.
Usually, a bimetallic limit switch will degenerate in the direction of too low of a temperature range because as the parts wear out inside, the mechanical tolerance widens (the tiny rod that pushes the contacts together gets shorter).
The high limit thermostat is by the thermal fuse. The operating thermostat is in the blower housing.
Check the fan impeller for broken vanes and lint. The impeller is directly coupled to the motor and should not turn without the motor. The fan housing and ducting should be free of excess lint.
Good luck.
May 02, 2010 | Samsung DV316LES Electric Dryer
Goodman 075-3 fan runs but no voltage going to igniter
One thing you can checkmis the continuity through the ignitor itself if you have continutity through that there is also some safeties it has to go through but the board is where the voltage is supplied for the ignitor. I would check the high limit and the roll out before condeming the board.
Dec 20, 2009 | Goodman GDS80904BNA Open Flame Heater
T-stat turns gas valve on,burner lightsburns long enough for fan stat to turn on fan,high limit shuts off gas valve,fan shuts off;repeats cycle
Probable causes include crack in heat exchanger, dirty pilot, bad high limit switch or bad gas valve. A crack can allow the fan to blow the flame off of the thermocouple or flame sensor. A dirty pilot will cause the same effect. The bad limit switch could cycle the system and a bad gas valve could be shutting off gas supply to unit.
Dec 02, 2009 | Off The Wall Heating & Cooling
Red light blinks 4 times, will only cycle once
the high limit is sensing the internal temprature of the furnace.If your filter is very dirty or you have to many of the registers/dampers shut it will cause the temp. of the furnace to exceed its rating and the high limit will open the circuit and shut down the flow of gas. Your blower will then run until the furnace has cooled and the switch will close and allow it to come back on. This is bad for your furnace, make sure your filter is clean and you dont have to many registers shut. If you have run the unit without a filter the problem could be much more sever requiring blower wheel and coil cleaning and possibly a cracked heat exchanger.
Sep 12, 2009 | Goodman GMS90703BXA Heater
Intertherm Furnace Will not stay on
possible dirty air filter low air flow causing high temp in fire box to trip limit switch or fan motor is bad hope this help let me know if you if this solved problem I may need more info
Jan 04, 2009 | Intertherm P3RA-048K Air Conditioner
Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping Logo
63 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
