Question about Toshiba Satellite L305-S5921 Notebook
SD Card reader 4gb driver needed
I have a Toshiba Satellite L305-S5919 and need a driver update for my SD Card reader to be able to read a Sandisk 4gb card. Is there such an update?
    President:
  • 2,600 Answers
Try this one....copy and paste to your browser and click 2nd page, Click on Driver Flash Memory SD, click on download.Once you have downloaded the file, Double click the file and it will self install. Follow the prompts.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2226352&rpn=PSLC8U&modelFilter=L305D-S5922&selCategory=3&selFamily=1073768663
Posted on Sep 06, 2009
How do I replace screen on satellite c655-s5132 with screen from satellite L305-s5919?
I'm sorry, but this isn't possible. The screens are two different sizes. The Satellite C655-S5132 has a 15.6" Widescreen display while the Satellite L305-S5919 has a 15.4" Widescreen display. The two aren't interchangeable. Sorry!
Thanks, and have a great day!
Sep 28, 2011 | Toshiba Satellite Laptop / Intel Celeron...
Toshiba satellite will not read dane 4 gb micro sd card
Do other 4gb sd cards work?
If not and it is an older laptop then you will need to get a new sd card reader.
Jun 23, 2011 | Computers & Internet
SanDisk ULTRA II 8GB won't read when installed in a laptop. Works fine in the Digital camcorder. Trying to import the footage on to a Fujitsu tablet laptop (12 months old). Reads the standard 2Gb memory...
No, it's a hardware issue. Your 8GB card is an SDHC card (the HC stands for High Capacity), but the card reader in your machine is clearly only compatible with the older type SD cards. SDHC devices will accept SD cards, but devices designed solely for SD cards cannot read or format SDHC cards.
There is no firmware update for this, your only fix is to buy an external reader compatible with SDHC cards for connection via a USB socket. Most new readers are fully SDHC compliant, but check the specs for shelling out your hard-earned...
May 14, 2010 | SanDisk ULTRA II 4GB Compact Flash Card...
Toshiba Satellite L305-S5919 Dual Monitor Help!!
Make sure the second monitor is actually plugged in and switched on when you make the switch.
Mar 21, 2010 | Computers & Internet
Can't read the SD driver. the Device Manager sees
try updating the card reader drivers or try with another sd card it`s possible that the sdcard to be broken
Mar 11, 2010 | Toshiba P25-S520 Notebook
I have a toshiba satellite l305-s5919 and i need to know how to reinstall the dvd drive that came with my computer?
the dvd that came with you computer is a recovery disc ; to recover your computer as new as you bougth it ;so to do so ; restart your com ;change the boot options to boot from the dvd first and follow what the dvd says and excuse my english
Oct 08, 2009 | Toshiba Satellite L305-S5911 Notebook PC
My toshiba laptop doesnt read SDHC card
sdhc cards are not backwards compatible with sd card slots. sd cards however are backwards compatible with sdhc card slots. newer card slots and readers are sdhc and sd ready but i'm afraid your only option is to buy a usb sdhc card reader. normally the 52 in 1 readers and ones like that work well and really don't cost a lot on ebay. the only other thing you could try is to put the sdhc card in an sdhc device (such as a camera) and link it up to the laptop that way.
Apr 04, 2009 | Toshiba Satellite M115-S3094 Notebook
Pc not recognizing sandisk micro sd
The Card Reader you are using is probably not compatible with SDHC Memory Cards (High Capacity SD). You may need to get an SCHC compatible reader or check the website for your product to see if the is a driver update. You can get a new reader for about $20 bones if needed. I had the same issue.
Dec 30, 2008 | SanDisk 4GB microSD High Capacity Memory...
Sd Card reader not recognising SDHC cards
When You Insert your SD card into the internal card reader, then the SD card is not recognised by the system and the SD card drive doesn't show there. The problem can be because of driver issue, system issue and device issue.
To fix the problem you need to go at device manager if there is a yelllow sign in SD card controller, the problem is most probably caused by a driver issue. Then you need to update the driver. You can also download the driver for your card reader.
Also, check if your SD Card is broken. You can also check it into different devices port.
If it is detected then you can backup of your data.
If the problem not resolved by any means and you require you SD Card data then I will suggest you read - https://www.stellarinfo.co.in/services/removable-media-recovery.php
Mar 03, 2017 | Computers & Internet
HELP w/ Sandisk 4GB MicroSDHC Memory Card with SD Adapter
First check it in ur laptop whether Card reader was installed or not.If ur laptop doesn't install drivers then Take from nearest service center and install the drivers.
Thanks
Mar 06, 2008 | Computers & Internet
Toshiba Satellite L305-S5921 Notebook Logo
445 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
