Question about Smeg 24 in. DWF614SS Stainless Steel Free-standing Dishwasher
What does the snowflake icon mean when it is illuminated in red please?
Flashing snowflake on ac no idea name of thermostat
Usually a flashing snowflake means you are in a time delay for cooling. If the snowflake becomes solid, cooling should start. If it never stops flashing, possibly it's bad. Turn power off to air handler, remove stat and put red green and yellow together and turn power back on. If indoor AND outdoor work and cooling begins the tstat is definitely bad.
Aug 18, 2017 | Heating & Cooling
What does the snowflake mean on a Honeywell thermostat in cooling mode. Also had the problem in the heating mode.
The snowflake means it's cooling. If the outdoor unit is not running then the problem is likely outside.
May 21, 2017 | Honeywell Heating & Cooling
What does the snowflake icon mean?
It is warning you that the outside temp means the roads might be slippery or icy.
https://www.google.co.uk/?gws_rd=ssl#q=vw+passat+snowflake+symbol
Nov 24, 2015 | 2012 Volkswagen Passat
I have a 2006 Jetta that flashes a snowflake and sounds a bell every time it gets below a certain temperature outside.
It is probably warning you that it is cold enough to have ice on the road if there is moisture.
Oct 06, 2014 | 2006 Volkswagen Jetta
What is the snowflake icon that is lit in my 1999 mercury cougar
the red snowflake means its super cold outside so watch for icey roads, and when its yellow, its just bout freezing, but still be careful
Dec 06, 2009 | 1999 Mercury Cougar
I have a sanyo aircon split system and i need to know the icons
the icons are snowflake = cool, raindrop = de humidification, fan blade = fan, sun = heat. hope this helps.
Jun 11, 2009 | Sanyo Split System Air Conditioner
I got a 2002 mercury cougar and there is a light that turns on an off once in a while it's the second 1 next to the wrench it looks like a snow flake what dos it mean
The yellow/orange snowflake means its between 42 and 33 degrees and the red snowflake means it's 32 degrees or below (fahrenheit).
Jan 28, 2009 | 2002 Mercury Cougar
Problem understanding Icons on Remote control
The snow flake icon is for your cooling, the sun icon is for heating, please rate this as it will help us if this was helpful to you, thanks,
mr.grzz
Jan 23, 2009 | Continental CE-AC75271 Ductless Mini Split...
Red pixel snowflake effect
this is called cell mis-fire. sometimes this can be adjusted by a qualified service technician and repaired. however most times the " y- main " board will need to be replaced
Jan 16, 2009 | Zenith Z50PX2D 50 in. Plasma HDTV
Why is the ''snowflake light'' showing up red in my car?
I have a '99 Mercury Cougar & I've been read somewhere that the snowflakes have to do with the outside temp. & traction. I think it's warning you that it may be slippery or icy. I've noticed that when it's +3 to about -2 or -3, the yellow snowflake shows up. Any anything colder than -3 shows the red snowflake. The other lights: the wrench comes up in yellow. That one has always turned on after a certain amount of km's & it's advising you that your car needs a check-up (that's when I know I should look into getting an oil change). You can turn this light off by holding down the two buttons above & below the 'clock' button. Hold them down together for at least 5 seconds & that wrench light should go off. Otherwise, there is a light for checking your breaks (upside down exclamation mark), low windshield fluid. I can't think of any other ones but I hope this helps.
Nov 18, 2008 | 1999 Mercury Cougar
Smeg 24 in. DWF614SS Stainless Steel Free-standing Dishwasher Logo
70 people viewed this question
Top Smeg Dishwashers Experts
Cleverer2
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
