Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
The brushes will not turn even though I have the switch on for the brushes
  • Chemist1961 May 11, 2010
    Check to see that the hose is not still set for upholstery
  • 294 Answers
When you move the swwitch to on, you are moving a baffle to allow air flow into the turbine to rotate the brushes. try to move them by hand with the machine off. if you cannot the turbine nees service. if you can check the tank lid is on, foam filter for dirt.
Posted on Oct 11, 2009
How do I repair Hoover Windtunnel floor/carpet switch? Brush will not turn but belt is not broken. I believe setting was hard floors and son forced the switch when the vaccuum was running.
The lever that switches from carpet to hard floors may be broken if it was forced, remove the cover to gain access. Replace both belts too. They may be stretched or worn even though they look good.
Dec 31, 2016 | Vacuums
Belt is intact but brush won't turn
Even though the belt is intact it can still be stretched or worn and will not turn the brush on the carpet. Here are the belts you need:
Dirt Devil Featherlite Belt
Apr 07, 2010 | Dirt Devil M085850 Featherlite Bagless...
Brush won't turn, belts intact
even though the belt is intact it can still be stretched and not turn the brush. You can get replacement belts here:
www.vacbelts.com
Dec 25, 2009 | Hoover U5753-900 WindTunnel Bagless...
www.vacbelts.com
Dec 25, 2009 | Vacuums
Beater brush does not work. Brush is clean and belt is not broke. Dyson 07 animal vaccum
Even though the belt may not be broken it might be stretched and if that is the case it will not turn the brush. You can get replacement belts here:
Dyson DC07 Replacement Belts
Nov 16, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
BRUSHES ARE NOT TURNING EVEN THOUGH THE BELT IS ON
you have a belt which attaches from the motor to the brushes. it has broken. open up from the bottom to gain access.
Sep 14, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Agitator brushes wont turn even after cleaning
the brushes will not turn even wen the switch is turned on
Aug 10, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Brushes will not turn
Look for something wedged between the belt and the turning components. The smallest thing can cause a lock down. Make sure hair is not wrapped around rollers causing it to tighten up at bearing sufaces.
Jul 08, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Brushes won't turn remain motionless as if cleaning hard floors even though button depressed could it be a problem with the brushes or button still under guarantee
There is a re-set button located on the brush head on the left side as viewed if you are standing directly behind the vacuum cleaner. It is black in color and is recessed slightly into the cover of the brush cover. It is round and about the size of the head of a country match and sticks up about 1/2 inch. Just press it to reset. Also, don't forget to press the grey on-off brush switch located beside the red on-off which is located near the top of the handle. Hope this information solves your problem. jawebb3@suddenlink.net
Mar 06, 2008 | Dyson DC18 all floors Bagless Upright...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
141 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
