Question about Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher never cleans, glasses gritty dirty -- Bosch terrible s
I have the same dishwasher and the same problem (Bosch shu43c02uc) . It did work well for about two years, then started leaving film on everything. BTW, I use the Cascade recommended by the manufacturer as well as Jet Dry. I cleaned the filter and nothing improved. Now, I wash the dishes by hand and let them dry in the dishwasher. There is something wrong with this machine. Also occasionally, the d/w does not drain at the end of the cycle. We checked the lines, etc. and they were not kinked and the filter/drain was not plugge
You obviously need to check and make sure that you've cleaned your filter system. it needs to be cleaned every couple of months. and also make sure that your washing fans, the ones that spray water, aren't clogged. they need to be washed out and de-clogged regularly as well... i had this same problem.. but it worked fine once i cleaned the system.
Posted on Sep 24, 2009
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Posted on Sep 07, 2009
My maytag W10199645 is leaving gritty residue on my mugs & glasses. how can i troubleshoot this?
Try using a dishwasher cleaner. You can get it at any supermarket that sells dishwasher soap.
Nov 06, 2014 | Maytag Dishwashers
My dishwasher is not cleaning properly. It leaves dirty gritty water which sticks to glasses cups etc
Run a product called "CLR" through the washer, that should do the trick, you may need to repeat it once a month. You can get this at any Hardware store throughout the USA.
Feb 07, 2012 | Dishwashers
My bosch shu43c02uc wont work at all and i think i need to reset it, how would you reset it and can you think of anything else that will help with the problem?
Hello
Welcome to Fixya.
Based on your post,"my bosch shu43c02uc wont work at all..."
This is the most common reason for these Bosch dishwashers not having power.
I would start by first shutting off the breaker. Then removing the kick plate ( access panel at the bottom ) and checking the wiring at the junction box for the dishwasher 120vac supply line.
Remove the murret's and visually inspect the wire for "resistance burn" and strip the wires back and install new fastener's if necessary to repair.
i.e.
This is actually quite common to find a wire connector come loose due to improper fastening and once the unit is in use for a while the connections heat
Sep 25, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Small gritty deposits glasses plates etc. All filters clean.
SPRAY ARMS ARE BLOCKED AND NOT TURNING REMOVE, CLEAN THEM THOROUGHLY AND LINE UP AT 12.OCLOCK START MACHINE AND CHECK POSITION OF ARMS AFTER A FEW MINS THEY SHOULD BE IN A DIFFERENT POSITION IF NOT THEY NEED MORE CLEANING
Sep 15, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher problem, Bosch
make sure u have jet dry in unit and put on higher number inside doors
Oct 02, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Film on dishes and inside dishwasher
Hi debstone
This is a common problem. what you should do first is pick up some GLISTEN and run it through on a full wash with NO dishes. the use electasol POWDER detergent and turn your jet dry down to 1. that should fix your problem. hope this helped
brent
Aug 01, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher
Although I previously posted with the same problem of a film on the dishes after cleaning, I did find a section in the owner's manual which solved my problem. Lift up the rinse aid cap on the inside door - the factory setting is on "4". The rinse aid works in conjunction with your local water, which has variations in it's hardness or softness. When your dishes are streaky, lower the rinse aid setting to 1 or 2. If your dishes are spotted, raise the rinse aid setting higher.
Sep 23, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
1,179 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
