Question about Air Tools & Compressors
Will not run at all - is there a reset switch on unit? I accidentally left it in the "on" position for several weeks in a shop and it would not run afterwards.
    President:
  • 1,167 Answers
Yes either on top off the pressure switch or on side off the motor or inside the casing off motor but it shouldnt trip out have you got oil inside as it may have run to hot and seizied it get back to me if any probz
Posted on Sep 06, 2009
I have a 1999 road king flhrci, and last week i changed out my seat to try another one, and accidentally unplugged the wire to the fuel pump sending unit. I tried several times to start it, and it...
Pull your codes i think you do it by alternating turnsignals ,,or cycle ing switch 10 times .w/ reset codes if there hard codes they will return ,,.you will find great help at harleytalking.com they have helped me good luck ....
Aug 16, 2011 | Harley Davidson FLHRCI Road King Classic...
Engine cuts off while driving it always restart may drive for a week than it does it again yesterday when it stopped the vehicle kept cutting off until i held the key in the foward position after i...
I have a 1998 Honda Accord EX that did the same thing for several months. The longer I let it go, the more often it did it. I took it to a repair shop and found out it was the ignition switch needed to be replaced
Jan 25, 2010 | 1998 Honda Accord
TRIO BOTTOM FREEZER FRIG - ICEMAKE WONT FILL WITH WATER. FRONT WATER DISPENSER WORKS. CHANGED FILTER ALREADY.
I have run into this problem in several cases so I`ll ask. Are you sure the ice-maker switch is in the ON position. I only ask because it often can accidentally get switched OFF because of it`s location on the side of the unit, (on 95% of modern trio unit`s) it is very easy to happen...and does.
That would be the first thing to check.
Let me know if that help`s. If so please take a second to rate the solution I provided you here at fixya.
If not, please reply and I`ll try to assist you further.
Good luck.
macmarkus :)
Dec 05, 2009 | Refrigerators
Last month screen completely filled with gray and white stripes running from top right to bottom left. Turned off, and restarted. This happens several times weekly, whether on internet or not, using...
That is most likely the wrong video card for that motherboard. Or the video card slot on that motherboard is faulty... I would recommend taking it back to the shop and letting them fix it, since this happened after you got it back from the shop...
May 14, 2009 | HP vs17
Frigidaire electric range digital display light stuck on
Try turning the power off to the appliance for several minutes or un plugging it.
Mar 30, 2009 | Frigidaire Kitchen Ranges
Charges up but won't turn on
If you press the reset for 30sec while connected to a pc via USB the unit will turn back on or failling that while connected to a pc put a small metal needle in the slot next to the reset slot and this will short out the unit back to factory default and it will come on
Mar 13, 2009 | Navigator Evesham Nav-Cam 7000 GPS...
Accidental short/spark - what part did i ruin?
YOU HAVE TOUCHED A HIGH VOLTAGE WIRE TO GROUND AS I READ YOR STATMENT. THAT WILL CAUSE A HIGH VOLTAGE BREAKER IN YOUR DISCONNECT OR MAIN PANEL TO TRIP. YOU CAN FIND CONTACTOR IN OUTDOOR AC MASH IT IN WITH AN INSULATED SCREWDRIVER AND SEE IF COMPRESSOR COMES ON . IF NOT YOU HAVE NO HIGH VOLTAGE TO UNIT FIND AND RESET BREAKER. or YOU CAN GO TO MAIN PANEL AND ALL DISCONNECTS AND CHECK FOR A TRIPPED BREAKER. REMEMBER MOST BREAKERS TRIP TO HALF POSITION, BUT CUTLER HAMMERS TRIP TO OFF POSITION. THE THERMOMSTAT CONTROLLED SWITCH IS CONTROLLED BY LOW VOLTAGE THAT TELLS IT WHAT TO DO, BUT THE WORKING POWER IS USUALLY HIGH VOLTAGE IF ANYTHING HUMS ETC YOU HAVE LOW CONTROIL VOLTAGE BUT IF CONTROLS CLOSE AND NOTHING HAPPENS YOU HAVE LOST A LEG OF POWER OR BOTH LEGS. LOCATE TEST AND RESET ALL SOURCES OF POWER ( HIGH VOLTAGE)
Oct 24, 2008 | Heating & Cooling
I have a pioneer gm-x404
The wiring is fairly straight forward. Along the top row of the ten pin plug =
(Left to Right)
Front Left positive,
Front left Negative,
Control wire from your stereo head unit should be thin blue wire sometimes listed as Remote Wire this switches your amp on and off via your head unit so you don't run your battery flat,
Front Right Negative,
Front Right Positive.
Bottom Row=(Left to Right)
Left Back Positive,
Left Back Negative
Centre Nothing
Right Back Negative
Right Back Positive
These are all inputs from your head unit.
To bridge from 4 channel to 2 you connect
one left speaker to Ch B Left Positive and Ch A Left Negative
one Right speaker to Ch B Right Negative and Ch A Right Positive
Ten Switching the Input Select switch to 2CH
Alternatively if your unit has RCA's on the back of the Head unit you can use them to run your subs.
Hope that helps.
Feb 28, 2008 | Pioneer GM-X4 Car Audio Amplifier
Can't do anything
It sounds the the hold switch is on..The Sansa c250 Hold Switch is located on the side of the device, and is used to prevent any accidental
operation. Once the Hold Switch is moved to the lock position, all function keys will be disabled.
Buttons on the Sansa c250 will not operate when the Hold Switch is active.
Feb 04, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Touch screen suddenly stopped responding!
Make sure your device is not locked. Lock button is the "Slide Switch" lower left side of device. If locked, will show a lock in upper right part of screen. Will unlock when you pull down the keyboard. This is also a very good feature to prevent accidentally dialing when getting in/out of your car etc...To unlock, slide switch to middle position.
Sep 04, 2007 | Samsung SCH-i730 Pocket PC
Air Tools & Compressors Logo
48 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
