Question about Kolcraft Tender Vibes 18189-TX Crib
I took the covering off to wash it, now I can't figure out how to get it back on. Seems like its going on backwards?
It is very difficult. My parents and I spent about 3 hours on it, and my husband came home and did it in about 5 minutes. You have to actually put the hard-wood board and frame part in the liner. You have to pull it really tight, and the bit of printed material with the Warning sign should fold from the outside in. This puts the ruffle part close to the top--but on the outside. The buttons will snap all around, and the strappy things on the bottom hook around that bottom basket part and snap. You will be able to see the wood before you put the little mattress back in. I really hope that helps--we were so frustrated.
Posted on Jan 29, 2010
I can not get the cover back on my oreck xl air purifier
How about making sure it's not on backwards... Hehe. It only goes one way. If it isn't going back on, you're doing it wrong. Mind the notches and line them up with the unit, logo facing forward of course.
Feb 13, 2013 | Oreck XL Professional Air Purifier
I have an Intermatic T104R timer set up for my pool pump. It seems that the clock is running backwards. Why is that?
If dial is not rotating clockwise and keeping correct time on 240Volt T104 timer, then WG1573 clock motor is probably bad.
Open following link for troubleshoot checklist:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Add a comment for more help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 06, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
Model WJSE4150B2WW ser# AF171808G GE washer agitates but won't spin with front cover off motor turns belt in the right direction for just an instant and then stops interior basket can be turned...
When spinning the motor freezes up and will not spin. I released the motor and took off the belt off and the motor ran fine. However the pulley that the belt is also on will not spin the proper direction, only backwards.
Mar 03, 2011 | GE WJSE4150B Top Load Washer
I have f18 message and need bit of help with the solution
We had the same problem with opening the pump cover;
The solution was taking more of the washing machine apart because there was something blocking it from the inside and preventing it from opening.
Trying to force it may cause more damage so unplug everything and tip it backwards - no need to lie it flat, do it just enough so it is stable and doesn't fall over.
Take off the front bottom panel on the machine.
Undo the screw holding the filter housing to the front of the machine and lower it inside the machine, next unscrew the hoses and disconnect the wiring from it. This will allow you to pull the filter out completely and to open it up.
Clean the pump, check that there's nothing in the pipes/hoses and then put it all back together again in reverse order to which you took it apart in. (i.e. put together the last part you took apart and work backwards).
Sep 14, 2009 | Bosch Logixx WFT 2806 Front Load...
Mod WFW 8400tw00 the bearing on the drum is out and the drum
http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Outer-tub-item-number-AP3773839.aspx
Bearing NOTsold separately...
Apr 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Harness straps off cosco car seat to wash cover, help reattaching
I need help putting the straps back on a Cosco 5-point car seat. Took it apart to wash and can't get it back together
Mar 08, 2009 | Century Encore 5-point Harness
Fisher Paykel GWL10US Washer won't spin
Look at my issue on "eco smart won't drain, smells hot". You could have same issue and your motor just hasn't burned up yet.
Oct 16, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel GWL10US won't spin
hi
if the pump works fine in diagnostic mode then it has tobe a module problem
cheers grant
Oct 15, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel GWL10 US spin cycle issue
check out another website. ths.gardenweb.com/forum/laundry for other fix it tips on FPaykel.
Oct 12, 2008 | Fisher and Paykel GWL11 Top Load Washer
Put back together
2 clips go in top center on back. one clip on each side by handle swivel points. also there is a string you thread underneath th front. Hope that helps
Nov 10, 2007 | Evenflo Aura Traditions Travel System...
Kolcraft Tender Vibes 18189-TX Crib Logo
579 people viewed this question
Top Kolcraft Baby Gear Experts
Timothy Shotwell
Timothy Shotwell
Level 1 Expert
Bill Boyd
Are you a Kolcraft Baby Gear Expert? Answer questions, earn points and help others
