Question about Kenmore Dryers
When I push the start button on it will not stay
On my Kenmore Electric Dryer, When I push the start button on it will not stay on.
  • Controlfrk
    Controlfrk May 11, 2010
    Model Number is needed to help
  • Controlfrk
    In general this is caused by a stuck centrifugal switch in the motor. Some models allow the switch to be replaced as a separate item while other manufacturers make you buy the whole motor. Model Number is needed to be of more assistance.
Dryerdoes noything has power
Posted on Sep 08, 2009
Kenmore dryer model 110.74994300 push start does not stay on
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
Kenmore Whirlpool Dryer Won Start Easy Fix
Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Jul 01, 2014 | Kenmore 62602 Electric Dryer
When I push the "push to start" button (knob) on
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Mar 14, 2011 | Kenmore Dryers
Dryer won't stay on
The motor centrifugal switch is not switching from the start winding to the run winding. The switch should stay in the run winding when the motor picks up speed unless power to the motor is interrupted or cut off. The switch is replaceable on most dryer models but sometimes it is an integral or built-in part of the dryer motor and failure of the switch requires the replacement of the motor. Indicate the exact model number of the dryer for more accurate troubleshooting and repair advice.
May 24, 2010 | Kenmore 63932 Electric Dryer
I have a kenmore he5 electric dryer. We have
I am having the same problem. I think there is a design problem. They have tried to fix mine 3 times (replacing the dryer with a new one on the first try!) My dryer is only years old. I'm so disappointed with Sears and Kenmore.
May 23, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore electric dryer stopped and wont start when button
Make sure there is 240vac then check the door switch, the start switch. Beyond the obviouse it is basic troubleshooting to work down to the failed component. Eric
Aug 08, 2009 | Kenmore 62602 Electric Dryer
Dryer won't stay on. I press the start button and it won't work unless I keep the button depressed manually
Hi, your start push button is malfunctioning. simply replacing this start switch will fix your issue.
May 20, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Must hold start button to run. no heat
disconnect power and remove lid. Test the door switch w a volt meter do so opening and closing the door not pushing switch if circuit stays open try pushing switch with finger. If pushing closes circuit then adjust switch.If circuit stays open replace switch. If switch operates with no problems then it is the motor. Check all connections and vacuum lint from motor
How old is this dryer?
Dec 30, 2008 | Kenmore Dryers
Dryers Logo
62 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
