Where is the CMOS battery located in the above Toshiba PSA 60U-02K015 Laptop
  • 1,906 Answers
It depens on the laptop;
remove hard drive covers and, accessory cover you should see a quater-sized disk usually with a colored dip plastic cover with two wires coming out of it leading to a tiny plug on the motherboard
Posted on Sep 06, 2009
    President:
  • 2,600 Answers
I believe your Cmos (RTC) battery is snapped into a metal clip on the main board and is not readily accessible through an access door. I believe the laptop has to be disassembled to get to it. I've included a link to assist in this project. Good luck
http://www.irisvista.com/tech/laptops/ToshibaA65/satA65_1.htm
My laptop Toshiba Satellite model: PSA 60U-02K015. The problem is the system keeps going in a loop in safe mode. It will not go to any windows program. How and what is the problem. How to download any pach...
During start up does it give you any options to start it normally?
Try hitting F8 during start up to see if your able to get it to boot normally.
Not sure what "pach" you are talking about.
BIOS shouldn't be the problem.
Sounds like you have a virus of some sort.
Nov 02, 2010 | Toshiba Satellite A65-S126 Notebook
I am working on a toshiba satellite l355-s7915. the owner's kid forgot her password, so I tried to remove the password with hirens active password changer, which failed. when I started up the computer, it...
Yes of course all Laptop and Desktop have CMOS battery. Screw the back cover of your laptop locate the CMOS battery and remove to clear the BIOS password. Or else you can reset the CMOS by removing the jamper.
Mar 29, 2010 | Toshiba Satellite A135-S4527 Notebook
Tryin to locate the cmos battery in a Toshiba L300 laptop
Turn off the laptop and pull the laptop batteries first, use a screwdriver to open the cover screw
After open the cover, and then slowly pull the cable red-black coil , which is the CMOS battery cable connecting the laptop to the board.
But make sure that you know what your doing because you can cause problem to then battery,motherboard or worse!!
Feb 05, 2010 | Toshiba Satellite Pro L300 Notebook
Where is the cmos battery located?
It is located on the mother board, under the keyboard.... It is the size of a quarter.... and may be soldered in on your Satellite M35x series machine.
Oct 23, 2009 | Toshiba Satellite M35X-S149 Notebook
Where is the cmos battery located on a toshiba satelite A105-s2131
There are several access panels on bottom of your laptop. These should have markings that designate what is behind each. CMOS battery can be either behind the hard drive panel or the memory card panel.
Alternatley, you can try this link to Tom's Hardware where someone is discussing how to do on a similar model. http://www.tomshardware.com/forum/247842-30-replace-cmos-battery-toshiba-satellite
Oct 11, 2009 | Toshiba Satellite 5005-S504 Notebook
ReplaceToshiba Satellite Pro 6100 laptop CMOS battery
the cmos batt is located near the cpu, is a quarter look alike batt. disconect it fron the two cable connector to the mb and replac e with a new one.
Jul 16, 2009 | Toshiba Satellite 5005-S504 Notebook
Want to replace cmos battery in Toshiba Satellite A10
On Toshiba laptops you hit the ESC key as soon as you turn it on & then you
are given the option to hit the F1 key to enter bios.
As to the cmos battery, they couldn't have hidden it better if it was the Queen's diamond!
It is near the bottom of the laptop on the right side, almost directly beneath the pause/break key.
Problem is, you have to disassemble the entire laptop to get at it!
Disassembly instructions for the Satellite A10 are here
http://www.irisvista.com/tech/laptops/ToshibaA15/SatelliteA15_laptop_disassembly_1.htm
Best of luck
Barb
Jan 25, 2009 | Toshiba Satellite A10-S100 Notebook
Computers & Internet Logo
638 people viewed this question
David Payne
David Payne
