Question about kawasaki Full Suspension Mountain Bike Men
What oil do I use in the rear end of a 2006 praire 4#4
    Problem Solver:
  • 3 Answers
I own a 2007 it takes 10 weight . that is only if has a wet rear brake. other wise it takes 80 weight.
Posted on Sep 14, 2009
Best thing todo is go and ask orealy autoparts store if im not mistaken is 90wieght that goes in the rearend but they will no better than me
Posted on Sep 07, 2009
When sitting at a red light my Mazda 3 idles real funny...vibrating almost sounding like a cats purr?
2006 Mazda 3
Applies to 2006 Mazda Mazda3:
Available engines
4 Cylinders 2.0L MFI DOHC
4 Cylinders 2.3L MFI DOHC
Could be a number of things - you're going to end up checking the entire car.
Off the top of my head:
a) exhaust component has rusted loose (usually catalytic converter heat shield). Any loose exhaust component (hanger/muffler, etc.) will vibrate at idle.
b) glove compartment door - loose hinge
c) motor mount - rubber part of metal/rubber mount vibrates loose & falls out.
d) transmission mount - ditto.
The Maintenance manual for your car says:
Clicking noise at idle or driving
1 Inspect Main (Crankshaft) Bearing - Excessive Bearing Clearance.
1 Inspect Rod Bearing - Incorrect Rod or Main Bearing Clearances.
2 Inspect Rocker Arm - Worn or Incorrectly Adjusted Rocker Arm(s).
3 Inspect Piston Ring Set - Worn or Broken Piston Rings.
4 Inspect Piston - Worn, Damaged, or Faulty Piston.
5 Inspect Fuel Line Assembly - Fuel Line Leaking.
6 Inspect Hose Clamp - Loose or Missing Fuel Line Clamps.
Tapping noise at idle
1 Inspect Valve Lifter - Insufficient Oil Supply.
2 Inspect Fan Blade - Broken, Missing, or Faulty Fan Blade(s).
3 Inspect Oil Pump Screen - Clogged Oil Pump Screen.
4 Inspect Oil Pump Drive Gear - Damaged or Faulty Oil Pump Drive Gear.
5 Inspect Exhaust Valve(s) - Burned, Worn, or Sticking Exhaust Valves.
6 Inspect Oil(Crankcase)Capacity - Lifters Need Additional Lubrication.
7 Inspect Oil Filler Cap - Oil Filler Cap Damaged or Missing.
8 Inspect Oil Pump - Damaged or Faulty Oil Pump.
9 Inspect Oil Filter - Old or Clogged Oil Filter.
10 Inspect Oil FLow Check Valve - Damaged or Faulty Oil FLow Check Valve Caused Loss of Oil Pressure.
Vibration while Accelerating
1 Inspect CV Half-Shaft (Remanufactured) CCT - Worn or Damaged CV Half-Shaft.
vibration while braking
1 Inspect Brake Rotor - Warped or Uneven Brake Rotor Surface.
Vibration while driving - entire vehicle
1 Inspect Brake Rotor Specs - Warped or Uneven Brake Rotor Surface.
2 Inspect Ball Joint-Lower - Worn, Damaged, or Faulty Ball Joint.
3 Inspect Ball Joint-UPPER - Worn, Damaged, or Faulty Ball Joint.
3 Inspect Wheel Bearing-Front - Worn, Dry or Damaged Wheel Bearing.
5 Inspect Tie Rod End - Worn or Damaged Tie Rod Ends.
6 Inspect Wheel Bearing-Rear - Worn, Dry or Damaged Wheel Bearing.
7 Inspect Wheel Hub Bearing - Worn, Dry or Damaged Wheel Hub Bearing.
Vibration in rear axle area while driving
1 Inspect U-Joint - Loose, Worn, or Damaged U-Joint.
2 Inspect Driveshaft - Bent, Loose or Unbalanced Driveshaft.
4 Inspect Differential Drive Pinion - Worn, Damaged or Broken Pinion Teeth.
4 Inspect Wheel Bearing-Rear - Worn, Dry or Damaged Wheel Bearing.
5 Inspect Pinion Bearing - Worn or Damaged Pinion Bearings or Yolk Shaft.
Vibration in steering wheel while driving
1 Inspect Wheel Bearing-Rear - Worn, Dry or Damaged Wheel Bearing.
Vibration in tire/wheel area while driving
1 Inspect Wheel Bearing-Front - Incorrectly Tightened or Installed Wheel Bearing.
Vibration under vehicle while driving
2 Inspect Muffler - Damaged or Burned Out Muffler.
Vibration in rear wheeel area while driving
Dec 01, 2011 | 2006 Mazda 3
I need to know what kind of real end oil should i use on my 2007 yamaha vstar classic 650
For the final drive oil you can use any 80/90 Hypoid gear oil. If you choose a synthetic Hypoid gear oil your rear end will run cooler. One quart of oil is enough for 4 or 5 rear end oil changes. Because the rear ends are so expensive (around $1000), I change my rear end oil every other engine oil change.
Jul 10, 2011 | 2007 Yamaha V Star Classic
What type oil do you use in the rear wheel?
If you are talking about the final drive oil you can use any 80/90 Hypoid gear oil. If you choose a synthetic Hypoid gear oil your rear end will run cooler. One quart of oil is enough for 4 or 5 rear end oil changes. Because the rear ends are so expensive ($1000), I change my rear end oil every other oil change.
Feb 19, 2011 | 1994 Suzuki VS 1400 Intruder
What type oil does the rear end and driveshaft use.
For the final drive oil you can use any 80/90 Hypoid gear oil. If you choose a synthetic Hypoid gear oil your rear end will run cooler. One quart of oil is enough for 4 or 5 rear end oil changes. Because the rear ends are so expensive ($1000), I change my rear end oil every other oil change.
Feb 19, 2011 | 1997 Honda VT 1100 C Shadow Spirit
Rearend whine 2006 v-8
check oil in rear end if its low check for leaks at pinion seal and rear wheel seals also fill with proper oil
Jan 23, 2011 | 2006 Ford Explorer
Belt slipping on my 97 400 kawasaki praire
if you talking about the clutch belt then you need to put a new one on.
Sep 25, 2009 | 1997 kawasaki ZXR 400
Should i change the differential oil at 125000.miles in my 2006
Yes and this easy to do. Just drain at bottom fill at top.
Mar 05, 2009 | 2006 Nissan Titan
kawasaki Full Suspension Mountain Bike Men Logo
107 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Phillip Edwin
Level 1 Expert
michael
michael
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
