Need to find where to find pump to clean - Washing Machines
    Top Expert:
  • Washing Mach... Master
  • 76,070 Answers
Inside the machine at bottom of washer tube
Posted on Sep 06, 2009
Where do I clean the pump filter? Light keeps lighting to clean pump. Whirlpool front loader. A+A 5kg / 1200 AWO/D 4505
You have a code telling you to clean the pump now thats a first are you sure it says clean the pump filter? more info as to why you are needing to clean the pump filter its not really easy trust me, unless you have done it before which i am guessing you havent.
Mar 07, 2016 | Whirlpool Washing Machines
Why will Haier HLP21E drain following wash cycle, but not drain following rinse cycle/before spin cycle?
Hello Michael;
My name is Peter. I am a retired field service appliance technician.
It sounds like your system just needs a good cleaning. Soap film will build up on the draining system components. You need to clean your float and insure it moves freely and makes contact with the float switch which turns on the pump. You may also need to disassemble your pump for cleaning.
There are products available for cleaning clothes washers, but these need to be used on a regular bases. I do not think they can clean enough to solve your current problem. Use after you have cleaned.
Dec 03, 2014 | Haier HLP21E Top Load Washer
I need to know the pressure the pump should be at when on i have an aboveground pool with a waterway pump.
There is no standard pressure your pump should operate at. Instead it will vary based upon the hydraulic load of the system and it's components. A range common to AG pumps/filters is between 10 and 16. As the filter gets dirty it will rise over time and then you'll need to clean the filter. A rule of thumb is 8-10 pounds over the 'clean' pressure you should clean the filter.
John
Jun 28, 2011 | Waterway 1 HP HiFlo Above Ground Pool Pump
How to clean pump?
You will need to remove back of washer, remove the pump and clean it. You may also need to clean any pipes going to and from the pump
Feb 06, 2011 | Whirlpool AWM6100 Front Load Washer
What's wrong the water will not spin out of my machine
It sounds to me that the pump or pipe is blocked, first check the pipe for any blockage if that is clean remove pump, open it (useually 3 screws) and clean that, if it is clean then your impeller is worn and needs to be replaced. Make sure the pump is running by actually, when pump are open start the machine and check if pump is running, if not check if all electrical wires are connected, also make sure that the opening that feeds the pump in the drum is clean as well
Dec 12, 2010 | Whirlpool Washing Machines
The milk pods do not fully empty
The problem is with the air pump motor. You need to take it apart and then clean the diaphragm and the air passages in the plastic housing. You also need to clean the tube from the pump to the multi valve. The air pump is located right in the middle above the water pump. Mine was white in color. Remove the electrical terminals and note location. There are four plastic tongs that need to be carefully pride apart then the unit can be cleaned. After cleaning return the motor back together and the machine should be working fine again.
Apr 18, 2010 | Braun Tassimo Espresso Machine/Coffee...
Whirlpool washing machine "clean pump" error light.
take top off machine. look down right side and you will see a disc about 50 mm in diameter, attached to this is a small flexible rubber pipe, take this off at the disc and blow through it,( you will need some type of pipe to connect to the rubber pipe).this worked for me with the very same problem.
Mar 09, 2010 | Whirlpool Washing Machines
My washer keeps flashing nd code -wondering if I need a new water pump
You likely need the drain pump cleaned. Unplug and pull the washer out. Remove cover in back. The pump is attached to the washer's floor. Pinch off the hose from tub to pump. There's going to be some water left in the pump and drain hose, so get a large towel ready. Remove screws attaching black piece (motor) to white piece (housing), pull out motor and clean the housing and motor impeller. Wear gloves, as it's always a nasty stuff what comes out. ;) Reverse steps to assemble the pump back together. If you don't hear pump running after completing all the cleaning, you may need to check the wiring and/or replace main control board located inside the console. If the pump seems to be running but no water is being drained - replace pump. for Maytag MAH5500B the part number is 25001052.
Vlad
First Choice Appliance
Jun 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Is there a filter and how/do I need to clean it?
Hi, These do not have filter that can be cleaned or changed. If you notice water draining slow at any time, you will need to open up the pump (not hard to do) and clean out any lint.
I hope this helps you. If I can assist you further, please let me know.
Vic
Jun 01, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool AWO/D 4505 Washing Machine
Unplug your machine and unclip the plastic trim panel across the bottom of the machine (front) to reveal the circular pump filter cover. Unscrew this cover with your fingers and remove any debris inside. Put the cover back on, clip the panel back on and try your machine again. Should be fine.
Aug 06, 2008 | Washing Machines
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
