Air Cond Belt needs new Belt steps to Replace
  • 128 Answers
You take the old belt check there is some numers like A 34 OR B 34 YOU ONLY TAKE THE OLD TO THE STORE TAKE THE SAME SIZING OK.
Posted on Sep 07, 2009
Aircon does not engage when turned on
the air cond requires the belt on or the pump cannot rotate as the air cond is belt driven on every auto that i know of. now if the belt is slipping it is a cause of one of two things. belt is stretched or not tensioned properly, or the air cond clutch is froze up. when you turn on with no belt the clutch is engaged and you will not be able to turn pump with ease. Install new belt and have air checked for proper freon fill
Sep 04, 2012 | 2001 Volkswagen Passat
Belt on air cond. keeps making noise when you accerate is i the adjustment pully or the air cond.
The A/C and other accessories are run by a "serpentine" belt that is not adjustable. It may be stretched or worn out and needs replacing. I try to use "gatorback" belts when they are available as they seem to grip the best and last the longest.
May 08, 2011 | 1999 Dodge Caravan
Can I put a new drive belt on bypassing the air conditioner or do I need to replace that first.The wheel is broke on the air cond...
you will have to replace the compressor, or install a a kit that replaces the compressor with just an idler pulley check with your local parts store for a compressor eliminate kit.....HAVE FUN
Nov 30, 2010 | 1993 Dodge Grand Caravan
What are the steps to replace the water pump on 1996 lexus es300
Hi, you will need some special tool like : External torx (star)socket, pully and regular tool (# 10,12,14 etc..metric) to change the water pump. First, you need to clear the room for the job because such as Two belts -(alternator,air cond., pump ect and pully) need to disconnected and take out the plastic cover, tire e.t.c. There are about ten bolts. The water pump is inside the plastic cover which turns by the timing belt. I strongly recomment to change the timing belt at the same time ($30.00-timing belt- It last about 80000-90,000 miles). Remember to mark the timing gear carefully when you take the timing belt out. This will help you put the timing belt back in the right degree for the engine perform. Water pump can only replace after the timing belt is disconnected.
Take care
Aug 03, 2010 | 1996 Lexus ES 300
BMW X3 aircon belt problem--keeps jumping out of crakshaft pulley
if air con belt runs off the pulley inspect the crankshaft damper pulley, it may be broken!
the air cond belt is a stretch belt with no tensioner!
Jan 21, 2010 | 2005 BMW X5
Kenmore Air cond. model # 2539750610
hi there pat.have u checked the cap on the fan motor.us a multimeter and use the mfd function on it to see if it`s say 50uf and if you get a 20uf reading.replace the the cap.
Jun 08, 2009 | Heating & Cooling
Serpentine Belt on a 1999 Ford Escort ZX2
If you have a book picture your are screwed. You do have a tensioner but it is between air con and powersteering pullys. In front from under you can put 15mm wrenchopend with a nother for leverage pull center bolt down to release tension. simple.
Jun 27, 2008 | 1998 Ford Explorer
Heating & Cooling Logo
52 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
