Question about LG RUMOR Cellular Phone
How do i get my micro sd to work on my lg triitan phone
Why isn't my LG phone recognizing my Micro SD Card any longer? How can I put music on my phone than?
Try another known working card in the phone. If that also does not work then you have a serious issue with that phone. If it works then parhaps your card has gotten corrupted and needs to be reformatted or replaced.
Aug 30, 2015 | LG Cell Phones
What type of sd card do i need for a LG ULTIMATE 2
It can handle an SHDC also. I have one in mine. Just pick up a MIcro SD card up to 32gb. I picked one up on Amazon for 12 bucks. Works great. Amazon com micro 32 gb sd card 0 15 Memory Cards Cables Accessories...
Mar 05, 2015 | LG Cell Phones
My lg pop wont read the memory card , and my other phones all read the memory card, no matter what memory card i insert to the lg it says" format memory card" then i do and still nothing, could...
I had the same problem with an HTC Aspire ( I think that's what it was called :} Anyway I formatted the micro SD card in fat 32 through my laptop using a micro sd to sd adapter and the sd card slot on my laptop. I then stuck the micro sd card back into the HTC and it worked. I heard formatting through another phone works too. Try it and let me know.
Nov 07, 2011 | LG GD510 Cell Phone
LG Tritan does not take PNY Micro SD
If you've tried to do a firmware update and it still would not recognize the chipset, then there is not much else you can do.
Aug 20, 2009 | LG RUMOR Cellular Phone
LG Rumor won't turn on
I had this problem too. Do you have a micro sd disk installed? If so, remove the micro sd disk. When you restart it should start right up, and then you can put the micro sd disk back in and all should work normally. I know, it is a big pain in the rear. For some reason when it boots up, IF there is a micro sd disk in, it tries to boot from the sd disk, and can't get out of that cycle. I don't like little bugs like this and will wait and see if I buy a rumor 2 or not the next time I replace one of my other phones.
Jul 09, 2009 | LG RUMOR Cellular Phone
Can i install a 2GB micro SD in my LG ku800
The SD card does not need any installation, just put the 2GB MicroSD card into your LG phone and it will work straight away.
This phone need Micro SD cards (smaller) and not regular SD.
May 17, 2009 | LG KU800 Cellular Phone
LEXAR MICRO SD CARD WITH LG CU 500
I have found that only my 1 gig Micro sd card works, I also have a 2 gig and it does not recognize it at all. I have been told the CU500 only supports up to 1 gig.
Jun 05, 2008 | LG CU500 Cellular Phone
Micro sd card in ke850
When the Prada 1 (KE850) was launched, it officially only supported up to 8 GB SD(HC) cards, but there are SD card manufacturers (i.e. Kingston) which claim that their 16 GB cards work in a KE850.
You could contact LG Customercare to confirm this or go with the 8 GB card to be sure ...
May 26, 2008 | LG Prada KE850 Cellular Phone
Phone
A micro sd memory card does not go in the LG CU400
Nov 20, 2007 | LG CU400 Cellular Phone
LG RUMOR Cellular Phone Logo
35 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
