Hi
Thanks for using FixYa. A dishwasher doesn't use a metal pipe however, the connections can be done using a metal pipe which are usually not suggested. You can look & diagnose the water inlet valve.
Disconnect the power source to your dishwasher before you conduct this or any other test. Either unplug the unit from the wall outlet, or flip the appropriate breaker in the circuit breaker panel.
Locate your dishwasher's water inlet valve. It should be located behind the lower kickplate panel in either the right or left corner. There will likely be two screws either on the top of the panel, or on its bottom. Remove these two screws, and then remove the kickplate. On some dishwasher models, the door has to be opened in order to gain access to, and remove the kickplate’s screws. Close the door before you remove the kickplate panel.
You will be able to identify the water inlet valve by the hoses that connect to it. There will be one hose feeding water from the house to the water valve, and another hose leading from the water valve that carries water away. Now is a good time to inspect your dishwasher's hoses, to make sure they aren't responsible for any water flow problems. Make sure the hoses are securely connected to the valve. Also check to make sure there are not kinks in the hoses. Kinks can impede the flow of water.
There will be two wires connected to the water inlet valve. If your dishwasher's water inlet valve has two solenoids, then there will be four wires. Label the wires so that you will be able to correctly reconnect them later. The wires are connected using slip-on connectors.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
