There isn't one. Because it is operated by putting the van into gear, it is probably a function of the BCM from a switch on the gearbox. Check the socket for continuity to ground and also for rust.
hello
u will find a lot of wiring diagrams and circuit diagrams help books and stuff like this at reliable-store
the girl in the chat box can help u instantly... im a frequent buyer there since Im a mecha nic so take help from there
1989 ford transit ,with a york 2.4 diesel engine a real white van man motor ,knocks any american big bore gas guzzling CO2 emmiting junk into shame .right what do want too know
Tachometer Wire Negative Wire (-): Any Wire That Is Note Red/Light
Green. The diesel tach wire is a green/white wire, located in a 5-pin
harness held up with tape behind the parking brake release.
Tachometer Wire Negative Wire Location: At Igniton Coils
According to wiring diagrams online... good luck with this. KEn
find out which auto transmission you have in the vehicle ( ask an auto transmission specialist shop) and then get the transmission manual from a technical book shop that covers that make of box
This should help you.
Remote Start
Tach Signal
TAN/YELLOW
AT MODULE ON FIREWALL-PIN#48
Ignition #2
GRAY/YELLOW
IGNITION SWITCH HARNESS
Ignition #3
Accessory
BLACK/LT.GREEN
Neutral Safety
Brake Light
RED/LT.GREEN (+)
AT SWITCH ABOVE BRAKE PEDAL
Reverse Light
BLACK/PINK (+)
IN HARNESS TO TRANSMISSION
Rear Window Defrost
BLACK (+)*
AT DEFROST SWITCH
