Question about Whirlpool Freezers
My ice and water taste funny in my Whirlpool ED25PQ. How can I soleve this issue
  • 304 Answers
You can install a filter in the incoming 1/4" line leading from the wall to the refrigerator. These can be purchased from Lowe's or Home Depot and come with installation instructions. Be sure to buy the whole new filter system not just a replacement cartridge.
If you have copper water line you will need a tubing cutter to cut the supply line for filter installation. If the line is plastic a sharp blade will do.
Good Luck
Posted on Sep 07, 2009
French door / lower freezer. The icemaker makes ice fine until tray is about full and then slowly drips water until about 1/8 of ice is frozen together with a upside down brown ice cycle fused to them....
The most common reason for this is that the fill valve for the ice maker is sticking slightly.
The brown ice comes from the leaking water sitting there on either the kickout bar or the gears and you are getting some residual rust deposit.
You will need to take the fill valve apart and clean it or possible replace it, I also recommend installing a water filter for the ice maker if you don\'t have one or replace the old one.
Calcium deposits in water are real hard on these small valves.
Oct 10, 2013 | Jenn-Air Freezers
The ice from my ice maker has a chemical taste...how do I get rid of it?
Run about 3 cycles of vinegar; then rinse with water. Run regular water through and then the ice should lose the chemical smell and taste.
Mar 30, 2013 | Igloo Cooler Igloo Portable Countertop Ice...
Drain tube opening clogs with ice inside freezer.
We are sorry to hear of the problem with your Whirlpool appliance. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Reviews@Whirlpool.com and provide your full name, phone number, address and the model and serial number for your freezer.
Apr 01, 2017 | Whirlpool Freezers
My ice cubes have a funny odor/taste.
Does your refrigerator have a water filter? if it has one it will be in the kickplate/grill below the freezer door. If it has one replace the filter.
Aug 17, 2011 | Whirlpool Freezers
Our Whirlpool WV1600NFW freezer has frozen water forming on the front of all drawers from top to bottom. The manual's troubleshooting does not address this issue.
first thing you would do is turn off or unplug the unit for 12 hours then when you plug the unit in before hand you would remove the rear panel on the inside of the freezer. then pluging in the unit again you would have to distinguish if this is caused by your icemaker and the water not going into the ice tray or if you have a defrost issue with your unit where as one of the defrost pieces such as the defrost timer the defrost heater or the defrost thermostat is not activating properly when these pieces do not activate it forms a build up of ice around the evaporator which is found in the rear of that panel but I personally think the issue is coming from when the water comes into your icemaker and maybe the icemaker is not recognizing that it is full and continues to pump water into the unit or the tube that brings the icemaker water is not aligned properly. If you have any further questions message me back and please remember to rank this opinion when our chat has fully concluded it allows me to help others in similar situations and if you are unable to defrost by turning the unit off for 12 hours you can use a hair dryer to defrost the build up of ice Thanks Rick
Apr 21, 2011 | Whirlpool WV1800NFW Upright Freezer
No water to ice maker or water dispenser
You're funny. This is a portable 12/120 volt model. It dosn't have a water dispenser or ice maker :-)
Dec 27, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Icemaker
You might have a frozen line. Also and this seems more important to you its prob to cold, Trust me to cold of a refrig will cause hollow ice cubes first leading to a frozen line. Clean your coils, if you have another refrig empty out into that, unplug it leave doors open a couple days. If you can get to water line use a hair dryer from a distance defrost line, turn down freezer half knotch 1 full one at maximum. should fix issues, especially if filter already changed. If this all check prob a clogged line, not just frozen.
Mar 15, 2008 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Freezers Logo
328 people viewed this question
Top Whirlpool Freezers Experts
christian nielsen
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
